It is currently Wed Apr 14, 2021 6:49 pm
 Post subject: 2001 SSEi, Hard Start
PostPosted: Thu Jul 10, 2008 4:01 pm
Year and Trim: 2001 SSEi
Hi everyone, my 1st post on the new BC.
Anyways, lately I've been having a hard start. Normally I turn the key and the car starts right away, now I have to crank it for about 5 seconds before it starts.
So far I have changed the fuel filter and had the injectors cleaned with no luck.
I'm guessing this is fuel related because the night before this started I noticed a sound after I'd turned off the car. I popped the hood and the round part of the fuel rail was making like a gargling sound.
Any help appreciated.
PostPosted: Thu Jul 10, 2008 4:15 pm
the round part of the fuel rail... are you talking about the little cylinder shaped thing called the fuel pressure regulator? it has a little vacuum line going into it?
PostPosted: Thu Jul 10, 2008 4:21 pm
No, it appears to be part of the fuel rail itself. About the size of an oreo cookie.
Even the diagram of the fuel rail in the FSM doesn't appear to show it.
PostPosted: Thu Jul 10, 2008 4:38 pm
Its just a fuel storage area.
Whats your fuel pressure?
-Andrew-
PostPosted: Thu Jul 10, 2008 4:51 pm
Not sure what the fuel pressure is. I've got no codes from a scan tool. I asked at two different parts stores but they didn't have fuel pressure gages.
I just found one on sears.com, so I'm gonna go buy it at our local sears.
PostPosted: Thu Jul 10, 2008 7:53 pm
Good plan, always a good tool to have. I think I paid $40 for mine at my local parts store.
When you test it, get the pressure at:
Key on, not started:
engine running at idle:
engine running at WOT:
key off, not started: (basically checking to see if it holds it pressure, or does it drop rather quickly)
-Andrew-
PostPosted: Fri Jul 11, 2008 10:02 am
Year and Trim: 00 Regal
For the key on part of the test, turn the key on a number of times to purge the tester of air. Then key on about 10 times to get the highest possible pressure. That's the reading you want to use.
97 Ei
97 GS
98 GS
PostPosted: Fri Jul 11, 2008 10:48 am
Don't do this while sitting in your driveway. LOL :angry4:
PostPosted: Fri Jul 11, 2008 7:14 pm
Here's what I got.
After turning the key: 50psi.
While running: 45psi.
Pedal down: 47psi.
Forgot to check it after shutting car off.
PostPosted: Fri Jul 11, 2008 8:47 pm
actually, that is the most important test for this particular problem, LOL
Your other readings look perfect.
When I had my Park Ave, it had a hard starting problem. There is a valve in the pump that was releasing the pressure in the system, so when I tried to start the car, there was no pressure at the rail. Priming the pump several times could let the car start. I'm assuming this is the same problem you are having.
Get that tester on again!
-Andrew-
PostPosted: Fri Jul 11, 2008 8:48 pm
When I had my Park Ave, it had a hard starting problem. There is a valve in the pump that was releasing the pressure in the system after it was shut off, so when I tried to start the car, there was no pressure at the rail. Priming the pump several times would remedy the problem and let the car start. I'm assuming this is the same problem you are having.
-Andrew-
There are no new unread posts for this topic. '01 SSEi hard to start
Oldman
Wed May 08, 2013 10:47 pm
xdhd350 View the latest post
There are no new unread posts for this topic. 2001 SSEi Will Not Start
nymeria
11
3452
Fri May 06, 2011 9:08 am
nymeria View the latest post
There are no new unread posts for this topic. 2001 bonneville ssei crank, no start
dematka
Mon Jul 16, 2012 5:33 pm
There are no new unread posts for this topic. 2001 SSEi intermittently won't start...difficult to diagnose
howdy
12
1782
Wed Sep 17, 2014 11:01 am
howdy View the latest post
There are no new unread posts for this topic. Odd Crank but No-Start, Cruddy Idle - 2001 SSEi
GP1138
Fri Jan 15, 2021 3:13 pm
GP1138 View the latest post
Users browsing this forum: Google [Bot] and 7 guests
