It is currently Wed Jan 23, 2019 6:04 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: I cant figure it out
PostPosted: Fri Feb 17, 2012 3:37 am
Year and Trim: 2000 ssei
I have a 00 ssei and it drives fine until I push the throttle more than half way down. Then it starts to break up. Ive replaced the plugs and wires. Could it be the coil packs going bad or maybe a fuel issue. Any info will be helpful.
 Post subject: Re: I cant figure it out
PostPosted: Fri Feb 17, 2012 3:59 am
When was the fuel filter last changed?
PostPosted: Fri Feb 17, 2012 4:21 am
I havent changed it. Its rusted to the line. Could that be my problem.
PostPosted: Fri Feb 17, 2012 4:53 am
I would definitely suspect that that is your problem. It is restricting the amount of fuel going to your engine. Do you pump premium fuel in your car like your supposed to?
Soak the rusted area with penetrating oil and let it sit a little while. Then proceed to try and loosen it.
PostPosted: Fri Feb 17, 2012 6:42 am
What is the boost gauge doing when it bogs down? Any SES lights on?
PostPosted: Fri Feb 17, 2012 7:25 am
The boost gauge reads just fine Im getting 12psi. I have ses light on I cant remember the code but its for the torque converter lock up circuit. That light is always on. Im on my third tranny in 4 yrs. I dont think the problem has anything to do with the tranny it shifts fine.
PostPosted: Fri Feb 17, 2012 7:33 am
It doesnt bog. It feels more like if my tank is empty. It starts pulling hard then stombles and pulls and stombles.
PostPosted: Fri Feb 17, 2012 7:34 am
Ok so when it stumbles.......... my 2 questions are the same.
PostPosted: Fri Feb 17, 2012 10:47 am
12psi on a 10psi gauge? Sounds like a plugged cat.
-Andrew-
PostPosted: Fri Feb 17, 2012 11:47 am
:stupid:
PostPosted: Fri Feb 17, 2012 12:38 pm
Year and Trim: Black 2000 SSEI and Red 2000 SSEI
Andrew I was going to say the same thing ....it sounds like a Plugged Cat
PostPosted: Fri Feb 17, 2012 1:19 pm
I had this problem twice, and both times it was the coil packs. The first time, the dealership played musical coils for several days and it fixed itself (temporarily). About a year later, I was able to find a dead one by testing it.
There's a great techinfo article for testing them. http://pontiacbonnevilleclub.com/forum/viewtopic.php?f=48&t=1683
PS: Get codes again. You ought to find some 030x codes that may help you further.
2000 SSEi, Napa Belden wires, Monroe rear shocks conversion, Dexcool delete
2000 SSEi with custom glass, body, door, and light kit
PostPosted: Fri Feb 17, 2012 1:29 pm
I agree with checking/replacing the cat. Also get the codes read and report any you have back here. It would not hurt to check the coils.
PostPosted: Fri Feb 17, 2012 3:57 pm
Go ahead and replace the fuel filter as well since you have not changed it and it is rusted on.
PostPosted: Fri Feb 17, 2012 8:30 pm
Ok guys I apologize for not giving you enuff info. I have a 3.4 pulley, intense racing stage 1 pcm, and a fender well cold air intake. I replaced my fuel filter today and it didnt fix the problem. Im going change the coil packs to see if that helps.
PostPosted: Fri Feb 17, 2012 8:52 pm
If the fuel filter did not work then i would say its a plugged cat.
PostPosted: Fri Feb 17, 2012 10:25 pm
Are you monitoring KR? Don't just change the coils, you will be just throwing money at it and may not fix it. Do the check as described in the link above. If you do not have a multimeter, you can get cheap ones just about anywhere that will work fine.
PostPosted: Fri Feb 17, 2012 11:52 pm
Year and Trim: None
I fifth the cat. Had the same type problem with my 89 Formula 350 and found bad injectors, replaced the coil, new plugs. Tried everything... oh yeah MAF too. Ended up being CAT. I noticed it when I parked it over the carpet in the garage there was a melted spot on there knew right away that was my problem.
Arent these cars prone to cat issues anyway? Bonnes that is.
Good luck.
2004 Saturn Ion 3 Quad Coupe
PostPosted: Sat Feb 18, 2012 1:55 am
I do not think cats are a problem with this car. I currently have 105,000 miles on my factory cat and it is doing just fine. My dads 2002 E150 goes through cats like no other and his van has a total of 4 cats
PostPosted: Sat Feb 18, 2012 11:35 am
FWIW, just because a coil tests good, doesn't guarantee it is good. Mine all tested good, but one caused a misfire and it wasn't found till it was replaced...
There are no new unread posts for this topic. Can somebody figure this out?
terrancew3
Tue May 06, 2014 11:13 pm
Archon View the latest post
There are no new unread posts for this topic. Can't figure this out...
MKMike
Tue Feb 06, 2018 12:08 pm
96 SSEi View the latest post
There are no new unread posts for this topic. The mechanics can't figure it out
Franksdad
Fri Jun 28, 2013 9:02 am
There are no new unread posts for this topic. Problem Just Can't figure out!
I/O
14
1440
Sat May 16, 2015 6:19 pm
I/O View the latest post
There are no new unread posts for this topic. Figure this one....my car rides like a tank!
steelergrl74
Sat Mar 31, 2012 12:44 pm
Ken_W View the latest post
