It is currently Tue Jun 18, 2019 4:36 am
PostPosted: Sat Oct 08, 2011 9:16 am
I have a 2004 Bonneville SE with 3.8. The coolant gauge is not working. Sometimes it will work fine but after driving the car for a while, it seems like it is sticking. Other times it will not work at all. After sitting overnight, everything seems to work fine for a little while, then problems start all over again. Other gauges working fine. GM dealer says dash is going bad. $450 to fix. Any ideas or fixes to this problem??
PostPosted: Sat Oct 08, 2011 9:23 am
unless they moved the coolant temp sensor on the 00+s it should still me on the passenger side of the radiator IIRC
its to early for my brain to work :sleepy1:
Wake asked SSEiman01 wrote:
why in the the world do you have or need Vaseline in your trunk??!!..well Leather cleans easy..
PostPosted: Sat Oct 08, 2011 9:26 am
I believe its on the block somewhere...although, these clusters are becoming more prone to failure like the 00+ gm truck clusters as they age...I'd try to find one used and swap it in, making sure to swap mileage chips of course ;)
92 Pontiac Bonneville SSE | L67/4T60E | 77K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule / Storage Occupant
92 Chevy Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Storage Occupant
03 Buick Park Avenue Ultra | L67/4T65E-HD | 190K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Summer Daily Driver
99 Chevy Tahoe LT | L31/4L65E | 238k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig / Tow Pig and Portable Concert Hall
04 Cadillac Seville SLS | LD8/4T80E | 201k mi | Red Jewel Tintcoat w/Shale & Grey Int. | Nicest Beater Around
09 Chevy Malibu LT | LE5/4T45E | 205K mi | Seafoam w/Blk Int. | Fuel Miser Daily
13 Ford Explorer XLT | 3.5/6F55 | 150k mi | Kodiak Brown w/Blk Int. | Unbreakable, somehow
James May wrote:
Hello.
PostPosted: Sat Oct 08, 2011 10:36 am
Temp sender is on the thermostat housing, below the upper radiator hose where it goes into the engine. It screws into the block, be sure to put teflon tape on the threads, no matter if it has sealant on it already or not.
Do you have access to a friend/neighbor/mechanic friend with a scan tool? If the sender is sending the right temp, then the motor in the cluster is bad. You can probably find a used one using www.car-part.com and swap the mileage chips inside. You need an SE cluster, the SLE and SSEi clusters are different and not really compatible.
There are no new unread posts for this topic. Coolant temp gauge
ParkAve666
Sun May 27, 2018 4:28 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Coolant Temp **How hot does your SSEi get**
Schweet97Z
Thu Jul 29, 2010 7:28 am
Schweet97Z View the latest post
There are no new unread posts for this topic. Coolant Temp with 180 Stat
ColoBonne
Fri Aug 15, 2008 6:15 pm
There are no new unread posts for this topic. Coolant Temp too Low Code?
redzmonte
Sat Dec 24, 2011 2:19 pm
There are no new unread posts for this topic. 2005 SLE Temp.Gauge Not Working
dougtoth
Fri Jul 20, 2018 5:33 pm
dougtoth View the latest post
