It is currently Tue Jun 02, 2020 5:29 pm
 Post subject: Replacing rear shocks..
PostPosted: Sat Sep 10, 2011 12:57 pm
Year and Trim: 2000 Pontiac Bonneville
How in the heck do you get that air hose off of there? :dontknow:
PostPosted: Sat Sep 10, 2011 1:04 pm
Squeeze the metal clip and it should pop right off.
PostPosted: Sat Sep 10, 2011 1:06 pm
I took the pin the was holding it off, but it seems stuck on there quite well.
PostPosted: Sat Sep 10, 2011 1:36 pm
Got it, thanks guys (:
PostPosted: Sun Sep 11, 2011 2:04 pm
When switching to the Monroe's do I need a special adapter of any sort. Are they bolt on and go?
PostPosted: Sun Sep 11, 2011 2:05 pm
If you got the Monroe MA822 Max Air's, they should be a direct fit.
PostPosted: Sun Sep 11, 2011 8:49 pm
AAP and AutoZone suggested getting an air hose adapter kit when I purchased my Monroe MaxAirs, so I purchased it. I found it to be completely unnecessary, and wound up taking it back after installing my shocks.
Many here at the Club suggest replacing your rear shock mounts with Moog mounts whenever you replace your shocks. I did this myself a few months ago. It was not a difficult procedure. Replacing the mounts is very easy when you have the shocks off, as you have already done 90% of the work at that point.
There are cheaper brands than Moog, but they supposedly fail quickly. Moog apparently lasts.
Mounts (Moog at least) are sold individually, so you will need two. Left/right sides are the same part.
Ken_W
There are no new unread posts for this topic. replacing rear air shocks and broke air hose fitting
SpMajeski
Mon Mar 28, 2016 12:38 pm
There are no new unread posts for this topic. Replacing rear shocks on 2005 buick lesabre
Joeu02
Mon Dec 18, 2017 3:45 pm
96 SSEi View the latest post
There are no new unread posts for this topic. ? on replacing air shocks with regular shocks
cvcman
12
1044
Tue Feb 13, 2018 4:54 pm
cvcman View the latest post
There are no new unread posts for this topic. Where to start- replacing shocks & struts
jethrow
Sun Feb 22, 2009 8:10 pm
Night Crawler View the latest post
There are no new unread posts for this topic. New Rear Shocks
dz09x
Thu Jun 07, 2012 8:46 pm
