It is currently Mon Feb 18, 2019 2:25 pm
 Post subject: Fuel Filter
PostPosted: Wed Jul 02, 2008 7:57 pm
I changed my fuel filter today, easiest thing i have ever done on that car. I forgot to have the oil caddy underneath, so i got some gas on the shop floor, but other than that it was easy as pie.
 Post subject: Re: Fuel Filter
PostPosted: Thu Jul 03, 2008 10:13 am
Year and Trim: 1997 SE
Yup!
As long as it has been done regularly and there's no major rust on the lines or fittings, it's a simple task.
PostPosted: Thu Jul 03, 2008 12:51 pm
The other hard part was finding the right wrench, we have fitting wrenches, but we had 15mm and 17mm, but no 16, so i had to use a regular wrench
PostPosted: Mon Jul 07, 2008 6:20 pm
Year and Trim: 2000 SSEi Dark Blue Matallic
3.4 pulley
Is the fuel filter located in the same place on Bonnevilles SSEi's 2000 and up?
PostPosted: Mon Jul 07, 2008 9:56 pm
Yeah, just under the driver's side rear door, needs a 16mm flare wrench and a 20 mm flare wrench, and a pail or oil caddy or something to keep gas from getting everywhere, as well as the fact that you NEED to wear safety glasses, unless you like rinsing your eyes out for 15 minutes. You have to push in the on the plastic piece on the other side, and don't forget to put the new one on, or it won't work. Geez, I might as well do a Techinfo for it!!
PostPosted: Tue Jul 08, 2008 2:55 pm
Manuals will always tell you to bleed the fuel pressure down first, to avoid just that spewing of gas all over that you mention. If you do write a TECHINFO article, be sure to include that. Even if some of us do it without. Another way is to wrap a rag around the joint as you're loosening it. Safest is to bleed the fuel pressure down first. :wink:
PostPosted: Tue Jul 08, 2008 3:00 pm
Year and Trim: ____
And remember to include that it needs to be changed every 15k miles :wink:
John
PostPosted: Tue Jul 08, 2008 3:26 pm
just curious.....so what type of fuel filter did you buy and where did you buy it from????
CAI - PEMs - ZZP 2.5" DP - PLIM - 180* T-stat - AL605s - 245/50R16 - cleared front & rear corners - 20% tint - GXP strut brace
PostPosted: Tue Jul 08, 2008 11:14 pm
I just got a microguard or whatever from the parts store in town, cost like 9 bucks. Parts City, a local franchise chain, there are like 5 in MN and one in IA, i think
PostPosted: Tue Jul 08, 2008 11:16 pm
How do you bleed the pressure?? You need a pail or something anyways, though, because there is fuel in it and the line, and you have to drain the filter or it will still make a mess.
PostPosted: Wed Jul 09, 2008 3:23 pm
It's true that I use a container to catch excess gas from the filter, but I was just mentioning that there are steps that can be taken to avoid the high pressure spewing of the gas when you first disconnect the filter.
Here's a decent generic link that covers the whole process.
http://www.autozone.com/az/cds/en_us/09 ... oPages.htm
Keep in mind that most of us do not actually bleed the gas from the schrader valve like they show, since not everyone has all the tools a shop has. Most just use a rag over the schrader and press down on it to relieve the pressure. Note that it also makes sense to back off your fuel filler cap to relieve tank pressure.
There are no new unread posts for this topic. Fuel pump & fuel filter
vogie01
12
3355
Wed Apr 25, 2012 2:34 pm
vogie01 View the latest post
There are no new unread posts for this topic. Is this the fuel filter?
viper79
Sun Dec 05, 2010 2:05 pm
There are no new unread posts for this topic. Fuel Filter
viper79
Sun Jul 25, 2010 11:38 am
viper79 View the latest post
There are no new unread posts for this topic. need help with fuel filter
spidey3479
Tue Jun 15, 2010 4:08 am
spidey3479 View the latest post
There are no new unread posts for this topic. maybe my fuel filter
SLEking
Mon Nov 15, 2010 12:24 pm
SLEking View the latest post
Users browsing this forum: peter and 11 guests
