It is currently Thu Feb 21, 2019 10:45 pm
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Feb 02, 2015 5:52 pm
Hi. Please start a new thread with your car's issues. If they are common issues, we can get this thread updated.
PostPosted: Wed Jul 29, 2015 7:44 pm
We are having new problems with the a/c blowing different Temps for driver and passenger. The driver's side is blowing get warm and the passengers side is ice cold. Could this be a fuse or a vacuum line issue.
Btw...my a/c compressor was just changed 300 miles ago...a link?
PostPosted: Wed Jul 29, 2015 9:16 pm
You are low on freon. The system calls for 2lbs, but it performs much better with 2.5lbs. Top off the system and you should be good.
-Andrew-
PostPosted: Mon Aug 31, 2015 7:23 am
Year and Trim: 2002 SSEI
This is great information. Thanks!
PostPosted: Fri Oct 23, 2015 5:29 pm
Year and Trim: '00 SSEI The works
Easily the best post I've seen thus far. Every problem I have had so far is on here haha.
So, Thanks.
Also my first post. So make room people.
PostPosted: Sat Dec 26, 2015 1:50 pm
Year and Trim: 2002 Bonneville SSEi Leather, Moon-roof, HUD.
Let me say this post saved me at least $1500 off the purchase of my SSEi.
The 3 doors were not working and the rear carpet was damp/wet.
I bought the otherwise super clean SSEi and immediately fixed the corroded splice under the Driver's seat.
I can't thank you guys enough for this post, Love my car.
HT.
PostPosted: Sat Sep 17, 2016 12:54 pm
http://www.gmpartscenter.net/auto-parts ... front-scat
For the time being, if you need a new bumper cover for your SSEi/SLE, this seems to be the best bet that I've found recently.
PostPosted: Mon Sep 19, 2016 9:27 am
redfury wrote:
http://www.gmpartscenter.net/auto-parts/2000/pontiac/bonneville/sle-trim/3-8l-v6-gas-engine/body-cat/bumper-and-components-front-scat
Except after shipping costs, it will be more than just walking into the dealer.
Dealer: $369.35
GMPD: $405.70
-Andrew-
PostPosted: Mon Sep 19, 2016 10:56 pm
Ah, good point. I wasn't aware that you could even GET the SLE/SSEi bumper covers anymore. It's really odd though that you can get those, headlights and tail lights, but that darn center reflector is MIA. Of course, it's a bad design. I think I figured out that it's the steaming of the seam that opens them up, or at the very least, it's the water that gets into them and then steams the inside up that causes the expansion and delamination ultimately, even though it has the two breathable plugs on the ends. I'm kind of surprised that they didn't just stick with the GXP style tail lights/center reflector for all future repairs...
PostPosted: Tue Sep 20, 2016 10:18 am
The GXP tails and center also delaminate over time.
-Andrew-
PostPosted: Tue Mar 21, 2017 2:51 pm
Year and Trim: 2003 SE
Hey guys my first post. My 2003 SE seems to have an occasional hard start issue. Usually fires right up, but lately it has taken 2-3 attempts to start and not every time in other words it may be fine for several tries and then I have to crank on it. Any ideas?? Also noticed coolant seems to disappear mysteriously. Don't see any puddles or any in the oil. Thanks:) :helpsmilie:
PostPosted: Tue Mar 21, 2017 3:12 pm
Quick guess, did you bleed the coolant zystem?
great car. Wrecked
Burnt Bonny.
PostPosted: Tue Mar 21, 2017 3:46 pm
No I haven't done anything yet, they both just started.
PostPosted: Sun Jun 04, 2017 10:25 pm
Year and Trim: 2004 gxp
Have you done a rear main seal and rear crank case cover gasket?
PostPosted: Mon Jun 05, 2017 3:03 pm
Well it seems that coolant loss was self inflicted. While getting the oil changed I had them give a look at the coolant issue and they found nothing after pressure testing the system but I did notice the cap is on with the arrow pointing at the tube. No problems since. Didn't think that arrow direction was that important, apparently it is. The occasional starting problems have not been an issue lately. I am trying to find the applique that goes on the trunk between the lights. So far all the one's that I have found are part of a whole deck lid for $300. :sad: Think I will do a little investigating on my own. Thanks you guys :banana:
PostPosted: Sun Dec 17, 2017 4:03 am
Year and Trim: 2002 ssei
i just happened to think isnt it a decently common issue for the ssei or 3800 motors in general to have water pump failings i know 3 people who own these and all had bad water pumps in a ssei and grand prix.
PostPosted: Sat May 26, 2018 10:49 pm
2003 SSEi
2004 GXP
Just replaced the fuel tank level sensor but it didn’t fix the problem. I found that autozone has complete wiring diagrams for most cars just have to create an account and look it up. Turns out that the fuel level sensor is driven by 5volts coming from the instrument cluster. I didnt have 5 volts. Plugged in tech 2 and said 200% fuel level. Actually ohmed out the level sensor and had the 40 ohms and the 250 ohms. Pulled instrument cluster and reinstalled and level sensor started working again. Pretty sure the problem was a bad connection where instrument cluster gets plugged in.
https://www.autozone.com/repairinfo/rep ... 3f80cb346e
02 SSEI, 1.94 Yella Terra,Gen5 , N*,2-1/4""Phenolic Intercooler,
I SELL, Phenolic Intercoolers, Pulley Pullers, Throttle Bodies, Etc...!!
PostPosted: Mon Jul 23, 2018 5:44 pm
Looking to replace my water pump. Don't have tensioner tool money. How do I deal with the tensioner loosening aspect with a socket wrench? Link to a thread appreciated. Tried a t50 didnt fit.
PostPosted: Mon Jul 30, 2018 10:52 am
You need a T47, not T50. Any standard ratchet will work just fine.
-Andrew-
PostPosted: Wed Jan 09, 2019 11:31 am
Just purchased a 2003 SLE and this post was very helpful!
There are no new unread posts for this topic. Common Issues & Solutions
SingsCountry1967
15
14107
Sun Apr 17, 2011 5:52 pm
seekinhighhp View the latest post
There are no new unread posts for this topic. 2000 bonneville common problems stumping me...
lazyhubby70
Tue May 19, 2015 6:17 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Any Common Problems fixed in 05's?
woody_02silverse
Wed Oct 15, 2008 9:13 am
woody_02silverse View the latest post
There are no new unread posts for this topic. common rust spots on 2000+ bonnie
Luxrain
21
2544
Mon Mar 14, 2016 8:53 pm
Luxrain View the latest post
There are no new unread posts for this topic. 2000 SSEi problems: No Start, Security Problems
94SilverSSEi
53
9348
Wed Nov 18, 2015 1:11 pm
Archon View the latest post
