It is currently Wed Jan 23, 2019 4:55 am
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat May 04, 2013 10:55 pm
Great list, very helpful. thanks
PostPosted: Wed May 15, 2013 8:36 pm
harofreak00 wrote:
I've spent many hours working on this update, but I know its not perfect. Feel free to post any questions, comments, additions, etc to further help the community.
Estimated Cost: FREE - $30 + labor, depending on if you have the materials on hand. [/list][/list]
    Filthy wheels
      Problem: The surface of the rim is covered in brake dust, rust or tar.
      Solution: Wash the wheels the best that you can with soap and water, and then use some Mother’s Mag and Aluminum polish on a rag. You can either work it with your finger, or with a Powerball Mini. http://www.mothers.com/02_products/05100-05101.html
      Estimated Cost: $5-10 + labor
Honestly i wouldnt use Mothers Mag polish. I had rear brakes that looked like dirty gold rims because of all the rust that was on my rotor from the previous owner. SOFT SCRUB powered through and completely shined it up. I had tried Mothers Mag polish but it was barely able to scratch the surface of the rust.
PostPosted: Wed May 15, 2013 8:44 pm
Nothing wrong with the Mothers polish, I use it often when detailing. When I come across filthy wheels though I use an acid wheel cleaner.
PostPosted: Thu May 16, 2013 2:20 pm
The mothers polish was great for the weak rust spots, but it left white crud all over everything that I didnt wipe with a towel, come back five minutes later, and wipe with a towel again. Dont get me wrong, it will get your wheel clean, but general SoftScrub made for a much easier clean.
PostPosted: Sun May 26, 2013 9:18 pm
Year and Trim: 2000 bonneville sle
on my 00 bonneville i get no air to come out of my rear heat/ac ducks in my center councel. i noticed if you pull on the bottom back of it will split and hinges at the top. and then you can feel the duck on the floor that goes to the center coucel i get no air there either. my hvac control wil be set on floor and vent and up front i get air out both the floor and vent any easy solution before i start taking it all apart?
PostPosted: Tue May 28, 2013 6:16 pm
Problem fixed pulled out center council there was carpet stuck between we're the 2 ducks meet
PostPosted: Mon Aug 26, 2013 11:11 pm
Year and Trim: 1996 bonneville se
2003 bonneville se
Also theninterior light fuse blowing due to sunvisors
PostPosted: Mon Sep 09, 2013 9:35 am
Year and Trim: 2000 SSEI
I noticed that the photos for the door water leaks in this topic are missing. Is there any way to get them re posted? Thanks
PostPosted: Tue Sep 10, 2013 9:39 am
Bump for a slow 1st post approval...
PostPosted: Tue Sep 10, 2013 7:36 pm
They aren't missing. For some reason, Photobucket says that we're over our bandwidth limit for the month, so they can't be viewed until next month.
PostPosted: Wed Sep 11, 2013 9:03 pm
The bandwidth will be reset on the next month cycle which begins on 9/16/13.
If someone wants to pay for the unlimited bandwidth it would be $30/year.
-Andrew-
PostPosted: Wed Sep 11, 2013 9:05 pm
Pontiac Bonneville Club General Collection? lol...
PostPosted: Wed Sep 11, 2013 9:12 pm
If anyone wants to donate to the bandwidth problem, Paypal me at andrew.suderman @ gmail.com
-Andrew-
PostPosted: Fri Nov 22, 2013 6:35 pm
Year and Trim: 2003 Pontiac Bonneville Se
Help! knocking noise, when I crank my 03 Bonneville Se, then its like a ticking noise. A couple of folks listened, one said engine replacement off the back, the other said it could be rod bearings or lifter.
PostPosted: Fri Nov 22, 2013 6:49 pm
This is an awesome list. Thanks for this great information.
PostPosted: Fri Nov 22, 2013 9:55 pm
Girlonfire, you should start your own thread in the 2000-2005 section. Post a video of the noise if possible. That will help us figure it out. Also, where are you located?
PostPosted: Fri Feb 14, 2014 3:42 pm
Year and Trim: 2001 SE
I want to thank you for this great thread. I have used several of these write ups. I just now finished installing a Dorman intermediate steering shaft and the link provided was more than helpful with pictures. What a difference that new ISS made! My next project is too install the shift kit I got to get rid of the hard shift.
Thanks again for all the info.
PostPosted: Sun Nov 23, 2014 11:13 am
I am having a bunch of problems with acceleration and heavy KR when the boost goes above 3. I have read that it could be a plugged CAT. How often does this happen? is there another way to diagnose the CAT?
Thanks
Wolf
PostPosted: Wed Jan 28, 2015 8:18 pm
I would post a new question about boost and kr. This is for showing how to fix the problems. You will get more replys when it in a separate post
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Mon Feb 02, 2015 2:12 pm
Year and Trim: 2000 sle
Great Forum,thank you so much for this, you have know idea how many of these problems my car has.
There are no new unread posts for this topic. Common Issues & Solutions
SingsCountry1967
15
14029
Sun Apr 17, 2011 5:52 pm
seekinhighhp View the latest post
There are no new unread posts for this topic. 2000 bonneville common problems stumping me...
lazyhubby70
Tue May 19, 2015 6:17 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Any Common Problems fixed in 05's?
woody_02silverse
Wed Oct 15, 2008 9:13 am
woody_02silverse View the latest post
There are no new unread posts for this topic. common rust spots on 2000+ bonnie
Luxrain
21
2494
Mon Mar 14, 2016 8:53 pm
Luxrain View the latest post
There are no new unread posts for this topic. 2000 SSEi problems: No Start, Security Problems
94SilverSSEi
53
9257
Wed Nov 18, 2015 1:11 pm
Archon View the latest post
