It is currently Thu May 28, 2020 4:37 pm
 Post subject: Rear window.
PostPosted: Sat Apr 23, 2011 5:31 pm
1992 Bonneville SSEi (Sold)
Hi All
The other day my passenger rear window wouldn't move and was making a sound that didn't sound good at all. I took the regulator out and found the cable was all kinked up and broken. I got a new cable and spool from the junk yard and went to put it all back together and I cant get it all the together. There is too much tension on the line. I was wondering if there is some kind or trick or a writeup on how to replace the cable.
Thanks Keith
2001 SSEi Bumbles
 Post subject: Re: Rear window.
PostPosted: Sat Apr 23, 2011 6:03 pm
Pull tighter, not kidding. I have removed part of that spring before to get them back together.
-Andrew-
PostPosted: Sat Apr 23, 2011 8:23 pm
I did the same thing. I cut about 5 coils out of the spring and still couldn't get it. The nut that's in the spring was bottoming out. I just wantsnt sure how much I could pull on it.
2001 SSEi Bumbles
PostPosted: Sun Apr 24, 2011 10:51 am
I use a large screwdriver for leverage to get the spool back in place. Put the cover over the spool, then slide a long screwdriver in the center of the cover and the spool. Put the tip of the screwdriver in the center of the bottom of the regulator where the tip of the motor goes.
There are no new unread posts for this topic. Attachment(s) rear window motor working on front window?
ptrfair
Tue Apr 21, 2009 10:28 pm
Archon View the latest post
There are no new unread posts for this topic. Rear window gone
fbn8248
Sat Nov 23, 2013 1:27 am
fbn8248 View the latest post
There are no new unread posts for this topic. Rear window issues...
Jason H.
Sat May 24, 2014 11:29 pm
There are no new unread posts for this topic. rear window defog
vendo
11
1481
Tue Nov 12, 2013 9:33 pm
vendo View the latest post
Bichselmnop
Sun Dec 21, 2008 11:35 am
Whitecrystal1 View the latest post
