It is currently Tue Apr 16, 2024 12:03 am
PostPosted: Tue Apr 19, 2011 10:15 pm
Several months ago I started getting a strange rattling every so often. It's hard to describe other than being a metallic rattle. The way it sounded, I really was thinking it was the passenger side seat belt mechanism in the top of the seat. Well just the other day I had the sunroof shade open, and it was rattling louder than normal. I leaned over, and that's when I was able to notice it was coming from above. It isn't the screws that are usually mentioned for adjustment. It seems to be the track that the sunroof sits on. The passenger rear corner of the glass is a little low (the adjustment screws I think are as far up as they can go). And I can reproduce the rattle by pushing up on the glass and releasing it in quick repetition. I don't get the same rattle if I push on the driver side. Does anyone know if this can be remedied?
PostPosted: Tue Apr 19, 2011 10:28 pm
If you raise the glass slightly by the vent mode, does the rattling stop?
Remove the 4 bolts that hold the glass in, remove the glass, activate the sunroof both to the vent and slide back functions. Inspect the movements of the track. If something is broken, you will be able to notice right away.
If both tracks operate correctly, but at slightly different angles, a calibration is necessary. I can explain further if needed.
1997 Corvette | 55k | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 95k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 260k | Official Bonneville Hauler
PostPosted: Wed Apr 20, 2011 8:12 am
Year and Trim: '02 SSEi
Mines pretty much the same way. Its like the rivets that hold the tracks in place are loose.
PostPosted: Wed Apr 20, 2011 5:38 pm
yeah, I checked this morning in the vent position and it doesn't rattle. If it ever gets warm again maybe I'll take the glass out.
PostPosted: Tue Apr 26, 2011 2:25 pm
Year and Trim: 2000 SSEi: Black w/ 145,XXX miles
I get a plastic rattle in my car that I believe is coming from the shade, I know this because I can put pressure on it and the noise goes away. Of course I don't have the headliner on it either cause someone else ripped it off before I got the car.
-Going off topic... How do you adjust the sunroof cause after a little while mine will drop down and leak.
1995 Jeep Cherokee Country- 200,XXX miles and running strong. 4.0L paired with a 5 speed manual. 4.5" long arm lift with 32" tires and regeared to make up for power. Best of all, shes a fire engine red!
2000 Bonneville SSEi- 145,XXX miles, bonestock for the time (don't hold your breath, it might be a long while)
Typos courtesy of LG Optimus G- yes, I do most of my trolling with my phone. Don't judge me.
PostPosted: Tue Apr 26, 2011 3:25 pm
If you removed the fabric from the sunshade, it will indeed rattle. The foam backing on the fabric is the only friction that keeps it tight.
PostPosted: Sat May 05, 2018 7:21 pm
Year and Trim: 2002 Bonneville SE STOLEN
2001-05 Bonneville GXPI
how do you calibrate the sunroof?
PostPosted: Sat May 05, 2018 11:35 pm
Using the switch, set the position of the glass exactly as you want it to be. Remove the motor from the assembly (drop headliner). With the motor unbolted, run the motor through its full cycle a few times. Bolt the motor back in and test it before putting everything back together.
There are no new unread posts for this topic. rattling noise
00bonne
Wed Nov 14, 2012 5:23 pm
2002FO View the latest post
00bonne
Mon Nov 12, 2012 7:20 pm
There are no new unread posts for this topic. I have a rattling sound on my 03 SC Bonnie
rynmcdonald
Mon Aug 08, 2016 11:05 am
MKMike View the latest post
There are no new unread posts for this topic. Teeth-rattling shaking at 50 mph +
MrPOPE
Fri Aug 07, 2015 7:28 pm
There are no new unread posts for this topic. Rattling and strut mounts.
spoiledred94
Tue Sep 20, 2016 4:36 pm
