It is currently Mon Feb 18, 2019 8:11 pm
PostPosted: Sat Feb 12, 2011 11:59 am
Year and Trim: 2000 Pontiac Bonneville SE
Hi. I was driving with the driver's side heat set on 90 degrees to warm it up quickly one cold morning here in Pa. All of a sudden I got a whiff of a burnt plastic type smell for a split second. Then I noticed the cool air was blowing from the driver's side heat vents. The passenger side and rear heat vents are blowing nice hot air. Can anyone tell me what happended? I have read about the air mix actuator...and suspect that it burnt out? If that is the problem...does the console have to be removed to get to the driver side actuator? I checked the diagram posted here but when I look for it there seems to be platic covers that may be hiding it. Any information on replacing the actuator will be greatly appreciated. By the way my car is a 2000 Pontiac Bonneville SE with 67874 miles on it and it's very clean. I just bought it and so far I'm still loving my 1994 Bonne' more.
PostPosted: Sat Feb 12, 2011 10:47 pm
You'll have to remove the hush panel (lowest part of the dash area) to get at it. The first part of the techinfo article for the intermediate steering shaft should help you there.
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=55&t=217
Then you'll have to lay on your back, and look up and toward the center of the car to see the actuator.
PostPosted: Sun Feb 13, 2011 4:09 pm
Thank you very much...I really appreciate your help. I will go out now and check it out. Thanks again.
[color=#0000FF][i][/i][/color] Mark Johnson
PostPosted: Tue Dec 06, 2011 3:42 am
Year and Trim: 2000 SSEI
Recently, I have found that I have the same problem you described in your initial post; I was curious if you found the cause of the problem/ have a solution to this malady.
thanks
thanks
There are no new unread posts for this topic. Attachment(s) 2000 SSEI heating problem...actuator?
jugriggs
Sun Feb 08, 2009 12:09 am
agrazela View the latest post
There are no new unread posts for this topic. 2000 Bonneville AC Problem question.
dandyd
11
334
Sat Jul 21, 2018 4:13 pm
dandyd View the latest post
There are no new unread posts for this topic. 2000 Bonneville Transmission problem
Amandaxyo
12
8405
Thu Nov 03, 2011 5:29 pm
Amandaxyo View the latest post
There are no new unread posts for this topic. Problem with my 2000 Bonneville SSEI fuel gage
hunterking
Tue Apr 07, 2015 8:34 am
There are no new unread posts for this topic. 2000 ssei air bag problem
saltvick
Tue Feb 01, 2011 8:31 pm
Users browsing this forum: Google [Bot] and 7 guests
