It is currently Tue Jul 14, 2020 3:08 pm
 Post subject: slipping transmission
PostPosted: Tue Jan 04, 2011 8:48 am
Year and Trim: 2001 Pontiac Bonneville SLE
A mechanic poured a quart of synthetic trick shift into my trans and three days later the transmission started slipping. is it the oil he put in or does it new a new one? if it needs a new trans what year and car should i look for at the junk yards. my car is a 2001 pontiac bonneville sle with 170,000 miles on it
2001 Pontiac Bonneville SLE. gutted air box. hockey puck mount.
1996 Ford F-150 XLT regular cab shortbed 4x4 351 Windsor
PostPosted: Tue Jan 04, 2011 11:26 pm
I would do a complete trans pan drop and replace the filter. Chance are, on a higher mileage car, that additives make the oil real slippery (kinda similar to synthetic oils) and worn parts will begin to slip. When was the last time the trans was flushed? If the trans was shifting just fine before, I would go this route first, would be much cheaper (~$70) compared to $1300...
My buddy put in synthetic trans fluid in his Grand Am and got the same results (car has 125,000 miles on it). Drained the fluid and put in regular, and trans has been fine the last 30,000 miles...
Eric
A few mods..
PostPosted: Tue Jan 04, 2011 11:36 pm
I wouldn't flush it, I would do a pan drop and filter, but start loosening your wallet. If you go JY route, I'd look for a low-mile Bonneville or Park Avenue that isn't supercharged. www.car-part.com will be a good place to start looking. Even if you have to have a transmission shipped from somewhere, it's gonna be cheaper than a re-man or a rebuild of your own. The only thing is you're now gambling with how well the replacement trans was cared for, even if it's low miles.
PostPosted: Wed Jan 05, 2011 11:47 am
Year and Trim: 2012 Eco
It's worth trying the cheap "fixes in a bottle" like Auto-RX and/or Seafoam Trans Tune first. I'd recommend the Auto-RX, as it made my transmission shift like butter in 1000 miles. Other members have had good luck with the Trans Tune.
Good luck!
There are no new unread posts for this topic. Bad PCS? Transmission Slipping
pinstriper38
Thu Oct 15, 2015 8:26 pm
pinstriper38 View the latest post
There are no new unread posts for this topic. transmission slipping at high rpm?
BrianT
Tue Mar 24, 2015 8:10 am
There are no new unread posts for this topic. Re-Built transmission slipping again in less than a year
Namrepus28
29
1486
Mon Apr 15, 2019 2:07 pm
Namrepus28 View the latest post
There are no new unread posts for this topic. Strange vibration and slipping Transmission
2000Silverbullet
15
2178
Tue Jun 09, 2015 1:26 pm
Archon View the latest post
There are no new unread posts for this topic. slipping and sliding in OR
spoiledred94
Tue Feb 11, 2014 10:57 am
