It is currently Tue Jun 02, 2020 5:28 pm
PostPosted: Sat Dec 18, 2010 12:12 am
Year and Trim: 2000 Boneville
I bought this car from a friend knowing it had a vibration but thought it could be fixed easy it wasn't real bad, but the more I drive it the more irritating it has became.
He is the details, the car runs and drives great every where except between 50 to 55 mph, it vibrates at this speed and is worse when going up hill, it is smooth as glass going downhill. It does this no matter if you are driving easy and slow or driving hard and aggressive, it has the vibration at 50 to 55 when in drive or overdrive, it also vibrates if you have your foot barely on the brake pedal to unlock torque converter. I have had the tires balanced and rotated front to back and the vibration is the same. The only thing I no for sure is the front drivers side trans mount is broke and I am going to replace that tomorrow, this would allow the drivetrain to be out of alighnment when under a load but why does it not vibrate under a load at 70 mph climbing a steep hill. I don't think it is misfiringor skipping as it only does it at 50 to 55 and you can change from drive to overdrive which changes the rpms a good bit and it still does it the same. I will get back to you guys after the trans mount is replaced, for further ideas on what to try next or to see what might have fixed your car.
Thanks
Gator
PostPosted: Sat Dec 18, 2010 12:57 am
What's up with mount? It was my guess right off. All the conditions you mentioned are also symptoms of a bad mount IIRC.
great car. Wrecked
Burnt Bonny.
PostPosted: Sat Dec 18, 2010 9:40 am
Every available option
X2
Get the torn mushy mount replaced with a puck mount and let's see how she handles before checking other things.
Mark
The Familyman's Trans-Am
Intense 3.4 MPS, Intense FWI, Intense PCM, copper NGKs TR55's, MSD wires, MSD coils, BWD ICM, MagnaFlow High Flow Cat, drilled 180 'stat, solid front mount, Monroe Max Air rear shocks, Moog rear mounts, Moog suspension bushings, cleared front corners, 190,000 miles
PostPosted: Sat Dec 18, 2010 5:03 pm
Ok, today was the first time I have drove the car in a month, my wife had said the vibration was different now than before, So when I went to get the trans mount and it did not have the rough vibration at 45 to 50 as before but a minor vibration felt in the steering wheel at say 60 an up now, after I changed the trans mount it drove exactly the same as before, but now it is shifting very hard, not good I beleive she said this comes and goes. The vibration is in the steering wheel at 60 and if you are on a bouncy road the vibration becomes worse as the car is on the bottom of the bounce like the car floats up and down on the downward dip is when the vibration gets worse, also I noticed when going 30 to 40 if you pull the wheel to the right the vibration is worse but pulling the wheel to the left it does not vibrate.
I jacked up the car and the left front wheel bearing has some play in it, the steering seem to be tight,
can the wheel brearing be my trouble
Also how do you fix the hard shifting transmisssion
PostPosted: Sat Dec 18, 2010 5:41 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Could be the bearing. But might as well get it fixed anyways if its bad.
PostPosted: Sun Dec 19, 2010 10:32 pm
Is there anyway to replace the bearings by themselves in the front hub assembly or is their just a whole unit replacement only.
Also has anyone been able to fix the hard shifting transmission problem, like how much in the pms switch by itself, I would love to fix it but not at 600 dollars, what damage will it cause by not fixing it.
PostPosted: Sun Dec 19, 2010 11:35 pm
The hubs are one unit, and you have to replace the whole thing.
PostPosted: Mon Dec 20, 2010 3:16 am
I don't know if the 2000+ Bonneys are the same as on my 94 or not, but on my trans, easy to reach and swap, is a transmission shift modulator. It comes stock and is unadjustable. For mine there is an adjustable modulator you can get. With a small screwdriver you can adjust the shift firmness or softness. May still not be what is wrong. It may still be a mount, or an internal trans problem.
great car. Wrecked
Burnt Bonny.
PostPosted: Mon Dec 20, 2010 10:32 am
The 00+s do not have a shift modulator. The harsh shift problem is often caused when code P1811 is set and the PCM commands maximum line pressure. (Edit - That will not turn on the SES light, nor can it be read by most code readers.) This is a good article on the problem.
http://www.tripleedgeperformance.com/Harsh_Shift__P1811.html
There are no new unread posts for this topic. more info on the vibration problem
alexcoqui
Thu May 21, 2009 5:15 pm
There are no new unread posts for this topic. 2000 Bonne AC Problem
dandyd
Tue Nov 10, 2015 10:16 am
dandyd View the latest post
There are no new unread posts for this topic. 2000 ssei air bag problem
saltvick
Tue Feb 01, 2011 8:31 pm
There are no new unread posts for this topic. 2000 SLE Sunroof Problem
Spl170s
Wed Jul 30, 2008 9:48 am
Spl170s View the latest post
There are no new unread posts for this topic. 2000 Bonneville Transmission problem
Amandaxyo
12
9135
Thu Nov 03, 2011 5:29 pm
Amandaxyo View the latest post
