It is currently Wed Feb 20, 2019 9:19 am
 Post subject: Oil Filter
PostPosted: Fri Oct 22, 2010 1:08 pm
Somewhere I saw a posting about using a oil filter from a 4.3 V6 on a 3.8.
I guess the reason was so a full 5 quarts of oil.
Other then that is there a real reason for this?
Is there an advantage?
:eek2:
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
 Post subject: Re: Oil Filter
PostPosted: Fri Oct 22, 2010 1:11 pm
Just having a bit more oil is the only reason. It'll help dilute contaminants and improve oil life.
PostPosted: Fri Oct 22, 2010 1:19 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
More filter area
PostPosted: Fri Oct 22, 2010 1:40 pm
And it will fit ok?
And this will work on any 3.8?
PostPosted: Fri Oct 22, 2010 1:46 pm
It will work on Series 2's with the Aluminum pan. That I can guarantee. The filter is for a 4x4 S10/Blazer w/ the 4.3L V6. Wix Number is 51036, NAPA Gold is 1036, K&N is HP-2001, etc. Do NOT use Fram of any type. They're all varying levels of garbage, with the orange ones being the worst of the worst.
The reason is for more oil for more dilution, better cooling, and longer life as well as a larger filter media for better, longer filtration.
PostPosted: Fri Oct 22, 2010 2:13 pm
Year and Trim: 2012 Eco
You can use it. The stock-sized one will filter just fine for most of the cars here. If you're doing it for more oil, the SII has no problem holding 5 quarts in the sump. Mine's had 5 quarts dumped into the engine at every oil change with zero issues in the past 40k miles I've done it.
Agreed, Fram are junk. I'd use a $1.50 Korean filter before a Fram. The $1.50 Korean Proton filter is constructed better...
PostPosted: Fri Oct 22, 2010 2:21 pm
ok....thanks for the info. :)
There are no new unread posts for this topic. oil filter
spoiledred94
11
1392
Sun Nov 03, 2013 3:51 pm
There are no new unread posts for this topic. maybe my fuel filter
SLEking
Mon Nov 15, 2010 12:24 pm
SLEking View the latest post
There are no new unread posts for this topic. Is this the fuel filter?
viper79
Sun Dec 05, 2010 2:05 pm
There are no new unread posts for this topic. need help with fuel filter
spidey3479
Tue Jun 15, 2010 4:08 am
spidey3479 View the latest post
There are no new unread posts for this topic. Missing Air filter?
Sat Jul 24, 2010 9:59 pm
Users browsing this forum: Exabot [Bot] and 3 guests
