It is currently Sat Oct 11, 2025 4:49 pm
PostPosted: Sun Oct 10, 2010 9:33 pm
Year and Trim: 2002 ssei
I just finished replacing intake gaskets, didn't replace thermostat gasket. Now for some reason it's leaking, and I didn't even take it apart! I removed the housing and the thermostat had a o ring type gasket, that was all. I replaced the o-ring from the felpro kit, and installed the gasket that came with it. It still leaks, is it needed with the o ring?
Thanks!
PostPosted: Sun Oct 10, 2010 10:24 pm
It should be more than just an O-ring. There's a rubber seal that goes around the thermostat. The thermostat sits sort of in the middle of it, and it's tapered. Generally, that is all that is needed. Some have added the paper gasket for extra sealing.
PostPosted: Sun Oct 10, 2010 10:29 pm
Thanks!
I would guess its leaking from the upper radiator hose, where it connects to the housing ..
Move the Pinch clamp to the housing and put a good hose clamp on there..
THose OEM clamps leave a weird seating, and once they are broke loose , never seem to fit right again.. ( for me at least )
Current mods - FWI, Intense 1.0 PCM, 3.4"- 3.5", Intense MPS, AL 104s, 180 Stat , Intense/TG shiftkit, Aeroforce Interceptor scan gauge
Upcoming mods- 1.9 rockers, 105#springs, Headers, 103s, 3.3, tune..
PostPosted: Tue Oct 12, 2010 10:25 am
I used the new seal from the gasket kit that goes around the t-stat, and a little RTV, no gasket this time. I drove it a while, and just got the slightest little bit of moisture around the gasket, it's not leaking at the hose. Is it possible to get the bolts too tight and not seal correctly? I know the manifold can be stripped, so I tried not to get it too tight.
PostPosted: Tue Oct 12, 2010 10:37 am
Your thermostat housing could be warped, but generally a bead of RTV will cover that up. I'd take a flat edge, like a metal ruler, and make sure both the housing and the LIM flanges are flat. Hopefully it's the thermostat flange that's warped, and then you can swap it out quick and easily.
There are no new unread posts for this topic. valve cover gasket? head gasket? 01 bonneville se
jrlugo45
Fri Jun 15, 2012 7:17 pm
PLAGUE PHANTOM View the latest post
There are no new unread posts for this topic. Blown lower intake gasket (hopefully) or head gasket
Hailey
15
6276
Wed Jun 25, 2008 10:26 pm
Hailey View the latest post
There are no new unread posts for this topic. questions on lim gasket and exhaust gasket
mfcordova2008
Wed Feb 23, 2011 2:05 am
There are no new unread posts for this topic. LIM gasket question
MrT
Tue Jun 10, 2014 3:32 pm
MrT View the latest post
mrbear3800
20
3493
Sat Aug 16, 2008 11:05 am
mrbear3800 View the latest post
Users browsing this forum: No registered users and 20 guests
