It is currently Thu Feb 21, 2019 9:23 am
PostPosted: Sun Sep 12, 2010 2:31 am
Ok here are some pics of the coil mod. Longer but softer springs. Had to be a bit creative with the compressors but they slipped right in. Take a look:
The ride is still tight with the air shocks in, but smooth and no longer has the feeling of riding in a rattling train car. Its nice GM left something to play with the sprung control arms in the rear.
BTW the easiest way to remove the rear spring is to put the car on stands, take off tire, use jack under the control arm to lift it and compress the spring, remove the shock and the link attachments and then jack the control arm up as high as possible the rest of the way. With the spring in the full compressed position, put on one the spring compressor and tighten the remaining small amount. When you relieve the jack the spring with virtually fall out by itself. About 30 minute job/side to remove.
There are no new unread posts for this topic. Rear coil spring weird!
flatlander745
Sun Feb 03, 2013 1:53 pm
flatlander745 View the latest post
There are no new unread posts for this topic. Rear driver coil spring perch rotted; need advice
quicksilver
14
1939
Sun Sep 30, 2018 9:00 pm
Jjohns1110 View the latest post
There are no new unread posts for this topic. Ran over a box spring
jedwards83
Sat Mar 26, 2011 1:47 pm
There are no new unread posts for this topic. air ride or spring?
override93
Wed Mar 11, 2015 5:26 pm
override93 View the latest post
There are no new unread posts for this topic. Broken coil spring
Merrillspontiac
15
1920
Sat Mar 28, 2009 10:16 pm
Archon View the latest post
cron
