It is currently Tue Apr 16, 2024 2:46 pm
 Post subject: Car dead as a door nail
PostPosted: Thu Jun 17, 2010 8:40 pm
Year and Trim: 2000 SSEi & 2005 SE
what is the amp of the battery? I have a trickle charger on it now but wanted to make sure I have the switch on right. What other things should I be aware of if there is absolutely no power?? Thanks,
Mac
2000 SSEi (Silver Eagle) cleared corners (before accident) new LIM gasket, drilled 180 T-stat, new plugs and wires, new valve cover gaskets, new Supercharger gasket, third brake light overlay. Hopefully soon to start more mods for performance. Also, 2005 White SE totally stock and will remain that way!
Thank you Bob & Vince for your hard work and kindness!!
PostPosted: Thu Jun 17, 2010 8:44 pm
The higher setting will be fine.
PostPosted: Thu Jun 17, 2010 10:43 pm
Corrosion would be another less likely cause. Is the battery old, or relatively new? If newer, I'd wonder what caused the battery to die.
PostPosted: Fri Jun 18, 2010 11:02 am
Yeah, I didn't see any corrosion on it. It looked pretty darn good actually...visually anyway. I put the trickle charger on it for a few hours then it started right up. The DIC is reading a 14.2 to 14.6ish when on the gas and down to about 13.7 at idle?? Still running so far...took it out last night and drove it to work this morning. We'll see what happens in the heat. Suppose to be in the 90's today. Just freaky that it was like there was no battery at all...no clicks, no lights, no nuttin'!
PostPosted: Tue Jun 22, 2010 11:22 am
Ok, update...after a brief trickle charge the car cranked right up and is now, apparently, working just fine except that every time I start it the DIC says to "check my tires". I have checked them, topped them off with some rear air to 35lbs and still showing "check tires"??? Any ideas anyone?
PostPosted: Tue Jun 22, 2010 11:30 am
Make sure all the tires are within 1-2psi of eachother, then on your DIC, select tire pressure and hold the reset button for 10 seconds or until it goes to normal. The car doesn't automatically reset, you have to do it manually.
1997 Corvette | 55k | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 95k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 260k | Official Bonneville Hauler
PostPosted: Tue Jun 22, 2010 11:32 am
On the DIC, press select until it reads tire pressure low. Depress and hold the reset button (5 to 10 seconds) until it reads reset, then release.
There are no new unread posts for this topic. Drive door controls are all dead
SHERIFTHOMAS
Sat Apr 02, 2011 10:44 am
Archon View the latest post
There are no new unread posts for this topic. All switches on driver's door are dead
Louiej99
Mon Sep 12, 2022 9:13 pm
dougtoth View the latest post
There are no new unread posts for this topic. Dead rear window & lock from Rear door module?
crackerjacksle
Tue Oct 31, 2023 7:57 pm
crackerjacksle View the latest post
There are no new unread posts for this topic. Dead 2003
jdecker
Sun Jun 25, 2017 5:31 pm
jdecker View the latest post
There are no new unread posts for this topic. Dead Battery
mr.haney
Wed Dec 26, 2012 11:12 pm
