It is currently Wed Jun 19, 2019 9:21 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 11, 2009 8:10 am
now wouls something like a pcm shift kit from zzp change these variables, or would you have to go with something like a lock-up bypass? :bstooges:
- Josh
______________________________________________________________________________________________________________
PostPosted: Fri Dec 11, 2009 3:42 pm
98+ changed the way the Lock up strategy works... The Torque Converter in lock will normally slip most if not all of the time( Not fully locked )... The TCC strategy was designed to do this, as well they needed a material that could handle this constant slip without cooking the clutch, in this case its a Graphite Woven Clutch...
The 96-97 was slightly different, it would fully lock... But the system was sort of adaptive, it may not fully unlock with various loads... It would ramp down the TCC apply to say 60% as you have added throttle, then it would easily ramp back to 100% in a smooth manner.. The 96-97 used a Carbon Clutch for this purpose.. and these were the first years with the low speed TCC apply.. It does help with around the town fuel economy...
PostPosted: Sat Dec 26, 2009 9:12 pm
Year and Trim: before cars
Just remembered the other day, if trans gets too hot, the PCM will activate hot mode. In hot mode, the PCM lowers shift points and commands lock up at all times in 3rd and 4th. It does this in an attempt to keep trans temps down. If a trans temp sensor fails, it could cause a hot mode. Not saying this is the problem, just saying it to make it known.
There are no new unread posts for this topic. Hard shifting
danny4748
Mon Jul 25, 2011 6:44 pm
danny4748 View the latest post
There are no new unread posts for this topic. Transmission Shifting
Tight
Fri Apr 08, 2011 9:29 am
Archon View the latest post
There are no new unread posts for this topic. Shifting issues
terrancew3
Fri Feb 07, 2014 6:32 pm
There are no new unread posts for this topic. long shifting
emtdan911
Sat Feb 23, 2013 1:10 pm
There are no new unread posts for this topic. Shifting problem.
darwinm
Fri Nov 14, 2008 9:42 pm
Whitecrystal1 View the latest post
