It is currently Mon Jan 21, 2019 1:42 pm
 Post subject: stall converter
PostPosted: Tue Apr 28, 2009 11:14 pm
Year and Trim: 2000 ssei
2004 GXP
after many many miles of fun my 00 ssei needs a torque converter it's my daily driver. i would like to get a stall converter but dont want to affect my everyday driving and gas milage. i know almost nothing about stall converters and the pros and cons can anyone help. what stall should i get? what exactly will i gain?
thanks,
dan
2006 Crown Vic, white P71 interceptor. Push bar, 35% tint.
TRADED IN! 2008 G8 Ignition Orange Metallic LY7, 47k miles, Flowmasters, all options but sunroof.
SOLD! 2000 SSEI Black, 180 t-stat, autolite 104's, 3.4" MPS, custom M&D CAI, 1/8" phenolic S/C spacer, throttle body heat sheild, solid front mount, MSD wires, shift kit, 3rd brake light overlay, cleared headlights, tinted and cleared tails, 20% tint, Syntec, ARP license plate bolts Goodyear Eagle GT's,disabled DRL's, 8000k H.I.D's, pilot angel eye fogs
TRADED IN2004 GXP Black. 53,000mi.... drop in K&N filter, 5000k H.I.D. lows, 8000k H.I.D fogs, switchback 5000K turn signals. cleared headlights. 20% Tint.
 Post subject: Re: stall converter
PostPosted: Tue Apr 28, 2009 11:15 pm
first off, how do you know you need a new torque converter? It's not a particularly common failure.
PostPosted: Tue Apr 28, 2009 11:29 pm
2004 GXP
many shops and different mechanics including myself all agree that its going out, through trial and error.
PostPosted: Tue Apr 28, 2009 11:31 pm
2004 GXP
I've replaced basically everything else. lots of torque converter "dust" stuck to the magnet in the pan after only about 7,000 miles or so. shudder, sometimes doesn't lock up etc. etc.
PostPosted: Thu Apr 30, 2009 8:09 pm
Year and Trim: 2009 G8 GT
Could be the diff as well.
I suggest a rebuild with stock parts with your current mods.
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
PostPosted: Sat May 02, 2009 2:20 pm
2004 GXP
the plan is to do more mods while i have the engine out. headers, pcm and possibly a slightly smaller pulley. so does anyone know how the stall converter would affect the daily drivability and gas milage? i was thinking of getting a stall converter through zzperformance because form what i understand the torque converter still goes into lockup unlike the converter intense offers.
dan
PostPosted: Sun May 03, 2009 10:20 am
From my discussions with various 3800 shops a stock torque converter is usually all you need. Unless your making a track only car I think a stock converter is fine.
415/391
PostPosted: Sun May 03, 2009 3:23 pm
2004 GXP
but the problem is that i dont want a stock torque converter. i blew out mine and so did my friend with a park ave ultra.
so in my opinion they are not strong enough.. so does anyone know a good stall to get for a daily driver and what will it do to my gas milage. thats all i want to know.
dan
PostPosted: Sun May 03, 2009 4:27 pm
http://www.tripleedgeperformance.com/
415/391
PostPosted: Sun May 03, 2009 11:30 pm
A higher stall converter is not stronger. Your converter stalls at about 1800 rpm, which is good for what the engine is and the power output. All a higher stall converter does is stalls at a different RPM to make better use of power. It's not stronger, it's different. You're not going to not have the TC go out because it's a different stall. It happens over time. Your TC went out because it was old and used, not because of the stall speed.
When you say dust in pan after 7k, does that mean your transmission was replaced 7k miles ago, or that the fluid was changed 7k miles ago? When my trans was rebuilt, they installed a re-manufactured TC in it. If they re-used your old one, that could be an issue.
PostPosted: Sun May 03, 2009 11:52 pm
2004 GXP
the transmission was flushed 7k miles ago.
PostPosted: Sun May 03, 2009 11:54 pm
Ok, that's what I thought. Changing stall speed isn't going to gain you anything until you're making way more HP than you currently have or have planned.
PostPosted: Sun May 03, 2009 11:59 pm
2004 GXP
ok thanks 00beast. you wouldnt happen to know where i could find a new oem converter besides a dealer would you?
PostPosted: Mon May 04, 2009 12:04 am
Stall speed has nothing to do with the amount of horsepower you have, but the rpms where you make your peak torque.
read here for more info:
http://www.summitracing.com/streetandst ... nt.asp?ID={7B20B3C7-AF72-42B3-9583-6BD43F224310}
check ebay for converters
PostPosted: Mon May 04, 2009 7:39 am
Any place that deals with transmissions will be able to get one for you.
PostPosted: Mon May 04, 2009 3:37 pm
2004 GXP
okay thanks for the help.
There are no new unread posts for this topic. 2 bonnevilles stall
trab
Sun Apr 13, 2014 2:15 pm
There are no new unread posts for this topic. Is it still my 02 sensors causing my car to stall?
drgonzo3705
Mon May 11, 2009 10:58 pm
Archon View the latest post
There are no new unread posts for this topic. Hesitation under acel, then stall?
Boostershot
12
1995
Tue Jul 02, 2013 5:32 pm
chepdog1 View the latest post
There are no new unread posts for this topic. Non 'charged 02 Bonnie - Stall
cprince
Fri Dec 14, 2012 7:50 pm
There are no new unread posts for this topic. Yep, another one of those.. Random dropout/sometimes stall
riktik
Thu Sep 19, 2013 2:20 am
xdhd350 View the latest post
