It is currently Thu Jan 17, 2019 5:18 am
PostPosted: Sun Jan 18, 2009 5:28 pm
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Hi I currently own a 1994 SSEi and we think there is something a matter with the engine
Well my question is that I am looking to buy a 1992 SSEi and am wondering how many of the parts from the 94 will work on the 92
If you guys could tell me what I could and could not use on the 92 would be greatly appericated
Pretty much the whole exterior is the same isn't
I heard that there were differences with the engine though
edit:Would I have better luck with a different year is there another year that would closer and what are the differences
Also why dont you guys just post all the differences of all the years from 1992 to 1995 for the SSEI
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Sun Jan 18, 2009 5:35 pm
Plenty of parts can go onto the '92. What changed in the engine department on your '94 was an upgraded supercharger and throttle body, PCM update (and its not backwards compatible), EGR system, and roller pivot rockers. The 1992 can't upgrade to those rockers unless you change the heads.
Bodywise, almost everything will swap over. Instrument cluster electronics was different starting in 1994, as was the ECC.
BonneMe wrote:
PostPosted: Sun Jan 18, 2009 5:45 pm
The EGR changed in 94, not swappable. Front exhaust manifold changed in 93, swappable between 92/93 if you swap the EGR pedestal, not sure about 94/95. The radio changed in 94, swappable with some wiring I think. I think the tranny wiring changed somewhere, I'm not sure of compatibility. Wheel options changed here and there, all swappable.
There are no new unread posts for this topic. 1994 SSEi Tuneup
SSEi95
Sat Aug 22, 2009 6:20 pm
Bonneville92V688 View the latest post
There are no new unread posts for this topic. 1994 BONNI SSEI TUNE UP
smp3371
Sat Jun 21, 2008 10:57 am
freneticburn View the latest post
There are no new unread posts for this topic. Decisions....Engine for 1994 SSEi
94SilverSSEi
Thu Apr 15, 2010 11:47 pm
There are no new unread posts for this topic. Trans swap, 96 sse into a 1994 ssei
95elite
Sat May 19, 2012 1:22 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. 1994 SSEi Injector Size?
LIL QIK
Fri Aug 12, 2016 11:32 pm
95naSTA View the latest post
