It is currently Fri Jan 18, 2019 7:02 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jan 14, 2009 10:59 pm
Year and Trim: 2000 SSEi w/ 99K
Sigh..this car has been a series of firsts for me including the first time I have ever done this...
I think i know how to fix it and will post more pics when i get a chance to. I might be distracted for a bit though...
PostPosted: Thu Jan 15, 2009 4:46 am
Year and Trim: 2002 Mazda Protege ES
been there, done that :sad:
-Matt
PostPosted: Thu Jan 15, 2009 9:20 am
LOL.... Been there and done that
PostPosted: Thu Jan 15, 2009 9:24 am
I am thinking i just need a donor stud and then press/hammer/cuss/drill/hand grenade the old one out. Then use the lug nut to pull the new one into place.
Sound reasonable?
PostPosted: Thu Jan 15, 2009 9:27 am
Sound reasonable?
You may have some fun knocking that stud out... Is it flush with the Hub or is there enough to get an old lug on it?
PostPosted: Thu Jan 15, 2009 9:36 am
Sound reasonable?
Big drift punch, a steady hand, and a 5# sledge hammer does the trick. Rotate the hub so the cut-out lines up with the stud you need to remove...then pound away. Couple of taps with the sledge hammer will pop it loose.
The new stud will slide in, wiggle it a little so the splines match up with where the old stud was, then pull it tight using the lug nut.
PostPosted: Thu Jan 15, 2009 10:14 am
Thanks Don and Curt,
Thats what I figured. I am a state worked so I am thinking that is my fun for monday while I am off. I PMed mike about a stud from the hub he just changed but he never got back to me yet. Anyone got a spare or am I boneyard bound?
PostPosted: Thu Jan 15, 2009 10:22 am
I have spares if you need one..
PostPosted: Thu Jan 15, 2009 10:36 am
I might just take you up on that. What are you doin monday LOL?
PostPosted: Thu Jan 15, 2009 10:45 am
I'll be at work till 12-1 Pm
PostPosted: Thu Jan 15, 2009 11:02 am
is that midnight to 1 pm? yuck :sad5:
PostPosted: Thu Jan 15, 2009 11:43 am
They are like $1 at the parts store. Buy new!
-Andrew-
PostPosted: Thu Jan 15, 2009 11:46 am
Really? I didnt realize you could buy them separate from the hub.
PostPosted: Thu Jan 15, 2009 11:51 am
Yup. I replaced some on my lumina back in the day.
-Andrew-
PostPosted: Thu Jan 15, 2009 11:54 am
Site Owner/Webmaster
'01 Sierra C3
They are pretty cheap from the store as Andrew said. I've done about 10 of them before (old truck had issues lol). Just make sure when you pull the new one thru with lug nut, that you don't damage the nut (maybe use a spare in case) and definetly make sure you get it thru all the way. Check the back side to make sure the head sits flat against the hub. If it doesn't, it will move while driving and can cause other issues with you rim and hub.
Owner / Admin
1995 SSEi / 2002 SSEi / 2001 Sierra C3 DENALI
PostPosted: Thu Jan 15, 2009 11:56 am
Ok guys. Thanks for the info. I will try to take pics and do a write up to pay back the knowledge.
PostPosted: Thu Jan 15, 2009 12:14 pm
Use a big washer between the nut and the hub while pulling it through. That way you don't hurt either the nut or the hub.
PostPosted: Thu Jan 15, 2009 2:13 pm
Yep they are cheap from the parts store..
PostPosted: Thu Jan 15, 2009 10:29 pm
Year and Trim: 2008 Aura XE
Don't use the lug when pulling the stud through, we learned in my auto class that you are supposed to use any normal nut to pull it through to prevent damage to the threads on the lugnut then use the lugnut to put the wheel on :wink:
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
PostPosted: Fri Jan 16, 2009 9:39 am
Ok i will head over to ACE and find a normal nut that fits those threads and then keep it forever. I will grab a few thick washers also to spread out the force..oh boy monday should be fun :roll:
There are no new unread posts for this topic. Broken rear wheel stud
Detailpro116
Mon Feb 05, 2018 6:45 pm
Detailpro116 View the latest post
There are no new unread posts for this topic. Replace front wheel stud? DONE!
Bob Dillon
Sat Sep 28, 2013 6:41 pm
There are no new unread posts for this topic. Belt sleeve stud and nut
haro1225
Wed Oct 12, 2011 3:56 am
Bing View the latest post
There are no new unread posts for this topic. What size stud go to exhaust manifold
Curt
Fri Jul 17, 2015 8:26 am
MKMike View the latest post
There are no new unread posts for this topic. Broken tie rod on 98 L67
Woosch
Tue Aug 25, 2009 2:51 pm
alec_b View the latest post
cron
