It is currently Tue Sep 22, 2020 12:29 pm
PostPosted: Fri Jan 02, 2009 12:13 am
Year and Trim: 1997 Pontiac Bonneville SE (H4U)
When I launch hard on the 94 SSEi, enough to throw you in the seat but not to excessively spin tires, you hear a noise coming from the passenger footwell. It seriously sounds like there's too big of a tire in the wheel well and I'm making a sharp turn. Passengers say that's exactly what it feels like too. But there's no rub marks on the wheel well lining? After I get to about 15 - 20 MPH in launch, it won't do it any more. Assuming because this is when the car makes the most torque. You can go 10-15 and mash the gas and it still won't make the noise.
Could the axle be rubbing something? Could the tire be rubbing the strut tower some how? Something's rubbing, don't think it's trans related considering that's kind of on opposite side, but what do you guys think? I could try recording it real quick if that would help.
EDIT: Here's video
Did I mention torque converter like vibrates sometimes as it locks, but locks hard?
- Josh
1994 Bonneville SSEi - 136k mi - FWI, 180* T-stat, Fresh upper gaskets
1997 Bonneville SE - 110k mi - H4U, 3.06:1, Tinted Tails, Bridgestone Potenza G009 225/60/16s
Performance: INTENSE PCM, INTENSE 180* T-stat, Gutted air box, K&N air filter, Ported LIM, Borg Warner Wires, NGK TR-55 Plugs, Adjustable Trans Modulator.
Bells and Whistles: Flowmaster 80 crossflow muffler w/ quad tips, 2x Kicker CVR12 Subs in vented box, 1000W RMS 1-ohm American Bass Amp, Alpine MRP-F200 4-channel amp (temporary), Infinity 60.7CS 6.5" Component System (front), Blaupunkt 3-way 6x9s (rear), Pioneer DEH-P6900UB Head Unit, Hardwired Whistler Pro 58 Radar Detector, Hardwired Navigon 2100 GPS
PostPosted: Fri Jan 02, 2009 1:38 am
Moderator
Moderator
Year and Trim: 09 G8 GT
You sure it's not traction control?
PostPosted: Fri Jan 02, 2009 2:03 am
Turned off, and brake pedal doesn't pulse. Also, this is the second set of tires/rims it has done it with.
- Josh
PostPosted: Fri Jan 02, 2009 2:06 am
Year and Trim: 2002 Mazda Protege ES
a bonnie i test drove made a near identical noise to that, but i coulda swore it was coming from the drivers side
-Matt
PostPosted: Fri Jan 02, 2009 2:09 am
This is definitely from the passenger side, I can't really feel it on the drivers side. I'm ripping into it this weekend so if it is something outside the diff/TC (if that's possible), I should see it.
- Josh
PostPosted: Fri Jan 02, 2009 12:23 pm
Had the same thing in my 95 SSEi, and Nates 95 SSEi, and I'm pretty sure the Grizz has the same thing. Never figured it out.
-Andrew-
PostPosted: Fri Jan 02, 2009 1:00 pm
Year and Trim: NEW 99SSEi
Daughter-97SEw/SLE Opt
98SSEi Wrecked
You might look into the bottom dogbone strut. If the rubber is coming out, the motor may be flexing more than it should and hitting something. Had that issue with the X-cars's top dogbone strut. Replaced it and no more noise.
Dangrus4060
99 SSEi Galaxy Silver w/Dark Pewter Leather, Bought Aug. '08 w/75,000 mi. Bose Sunroof Michelins 35% Charcoal Tint(max. legal) Gutted Airbox w/K&N Drop-in 180Deg. Drilled Stat. Flushed Dex-Col Castrol Edge 10W30 w/PureOne Dual Chromed-Stainless Exhaust Tips Avital - Avistart 5303 Remote Start w/Security SilverStar Ultra's HL Rebuilt Motor w/New Crank & L32 Powdered Metal Connecting Rods
Daughter's 97 SE w/SLE White w/Dark Pewter Leather Bought Apr '06 w/153,000 mi. AM/FM/CD w/ 7-Band EQ Gutted Airbox w/K&N Drop-in
180Deg. Drilled Stat. Flushed Dex-Col Valvoline Max Life 10W40 w/Pure One Avital - Avistart 4300 Remote Start w/Security
PostPosted: Fri Jan 02, 2009 1:37 pm
Yes the 94 SSEi (Grizz) still does that. Can't figure it out.
It was worse before we changed the torque axis mount.
The dogbone looks OK but haven't changed it yet.
Let us know what you find.
PostPosted: Fri Jan 02, 2009 1:54 pm
Your brake pedal won't pulse with traction control. Only ABS. You typically won't FEEL anything with regards to TC, but you can sometimes hear it.
PostPosted: Fri Jan 02, 2009 2:03 pm
If the TC is turned off, is it still possible that it is engaging?
PostPosted: Fri Jan 02, 2009 2:51 pm
If the light comes on, it's off. 92-95 don't use applied braking AND retarded timing, just applied braking (which you don't feel in the pedal).
The light signal is coming from the 'puter (EBCM) after it determines the TC is actually disabled or in a fault condition.
PostPosted: Fri Jan 02, 2009 3:05 pm
So it can't be the TC because it is always off and the light is on.
It almost sounds like the axle is rubbing on the frame for a second or two. :bluetwitch:
PostPosted: Fri Jan 02, 2009 3:24 pm
x2
- Josh
PostPosted: Fri Jan 02, 2009 5:21 pm
Year and Trim: '07 MDX | '13 TL | '06 GTO
on my old 98 SSEi it was caused by worn out input clutches. Thats what they said at least. replaced em and the problem went away.
PostPosted: Fri Jan 02, 2009 8:58 pm
F@#$%# Transmission !! :angry7:
I think we may be missing the WCBF this summer. :sad:
PostPosted: Sat Jan 03, 2009 12:52 pm
Year and Trim: 1996 SSEi
are you sure you see the light on the cluster saying traction off? oddly i cant see the orange/yellow glow unless the wheel is blocking it. cause thats what it sounds like when i spin the tires with traction control still on.
Aerospace Propulsion Technician USAF
Airman First Class,
.:Michael Lyons:.
parts available on 96 see thread http://pontiacbonnevilleclub.com/forum/viewtopic.php?f=27&t=15185
PostPosted: Sat Jan 03, 2009 12:53 pm
Traction control is off, and I can feel the pedal pulse in both my bonnies if TC is activated and I touc hbrake
- Josh
PostPosted: Sat Jan 03, 2009 1:18 pm
Year and Trim: ____
I had this problem with the 89, long before I joined the club...I replaced all the engine and transmission mounts, since they all appeared to be original, and i appeared to have WAY too much movement. Fixed it, never heard it again.
Oh, and the 93 was making SORT of the same sound, and I replaced the dog bone because it was..cooked...and it made it much less noticeable.
John
PostPosted: Sat Jan 03, 2009 2:41 pm
The only mount I haven't changed yet is the dogbone. It looks OK but I haven't taken it out to inspect in detail.
A spring job. I have a new bone.
For now, the noise is acting as a great deterrent to a young driver with a heavy foot. :wink:
PostPosted: Sun Jan 04, 2009 6:22 pm
Didn't get to it this weekend between work, a wedding and a Christmas dinner for work. Probably tomorrow...
- Josh
There are no new unread posts for this topic. SSEi Power Loss under heavy throttle
hobbie2k
Wed Feb 01, 2012 2:01 pm
hobbie2k View the latest post
There are no new unread posts for this topic. '98 Pontiac Bonneville SSEI Noise
ladymay123
Sat Aug 06, 2016 9:28 pm
MKMike View the latest post
There are no new unread posts for this topic. rattling noise on side of '93 SSEi tranny
Billha
Fri Feb 11, 2011 1:32 pm
J Wikoff View the latest post
There are no new unread posts for this topic. What is this noise? Spark knock? —1994 SSEi
Highway Patrol
Tue Feb 19, 2019 11:25 pm
Highway Patrol View the latest post
There are no new unread posts for this topic. 1996 Bonneville SSEi supercharger noise?
markr
Sun Mar 23, 2014 10:54 pm
cron
