It is currently Tue Sep 25, 2018 11:34 am
 Post subject: codes
PostPosted: Fri Nov 14, 2008 11:26 am
Year and Trim: 1994 SSEI
check engine came on ... then went off..
codes
PO321 ign sys prob.. 18x interrupts lost signal
PO361 ign sys prob elec spark timing
est not toggling.
can i get some ideas on what im looking at. ???
clear corners,tinted tails , 180 drilled tstat, flowmaster hi flow cat, too dark tint. k&n CAI , chrome tips. 20'' rims 245/35/zr20,Energy suspension end links,Bendix ceramic brakes,painted calipers,JVC KD-AVX 33
 Post subject: Re: codes
PostPosted: Fri Nov 14, 2008 12:07 pm
Your harmonic balancer has two rings of interrupter teeth on the back. The 3x and 18x rings. They are used for spark timing. These rings are sensed by the crank sensor. In all likelyhood, you have either a failed crank sensor or wiring problem, but it still could be the ICM. Even though the PCM takes over the ignition and fuel pulses after 400 rpm's, the signals are still sent THROUGH the ICM.
(your icm only really controls ignition and injector pulses for the first 400rpm's of a start attempt, at which time the PCM and ICM 'handshake' and the PCM takes over).
PostPosted: Fri Nov 14, 2008 6:22 pm
ok.. i guess im off to the mechanic tomorrow..
sigh...
PostPosted: Mon Nov 17, 2008 9:41 am
mechanic says ,, replace icm and crank sensor.
icm is easy (apparently) so i may take a stab at it.
cranks sensor is harder as its under the car, hoist is invaluable.
PostPosted: Mon Nov 17, 2008 11:19 am
You don't need a hoist for that...jackstands will do just fine. You WILL need an impact wrench to get the balancer off though.
As far as the ICM goes, examine all your wiring. That harness tends to get pinched in several areas, and if you have oil leakage up front, that will cause the ICM wiring to go soft in a few spots, degrading the insulation and leaving bare wire exposed. It also would not hurt to check the surface ground @ the ICM (Later ICMs added pin "K", which was the only one missing when you look at the connector. This was an additional ground, for reliability I am guessing)
BonneMe wrote:
There are no new unread posts for this topic. Help with codes
JMH1950
31
2084
Wed Oct 29, 2008 3:34 pm
JMH1950 View the latest post
This topic is locked, you cannot edit posts or make further replies. Air Bag Codes
nunesjeff
Mon Nov 16, 2009 9:12 pm
J Wikoff View the latest post
There are no new unread posts for this topic. A few codes...ugh.
ddalder
Sat Sep 30, 2017 4:24 pm
ddalder View the latest post
There are no new unread posts for this topic. A couple of codes: Can you help, please??
labonnevillastrangiato
Mon Jul 21, 2008 8:49 pm
93RedSled-SSE View the latest post
There are no new unread posts for this topic. Unreadable codes
Leejr57
Tue Aug 11, 2009 3:05 pm
Leejr57 View the latest post
