It is currently Wed Jan 23, 2019 1:26 pm
 Post subject: Transmission lines
PostPosted: Sat Oct 18, 2008 11:45 am
Year and Trim: 1993 SSEi
Mine are leaking bad. Can someone hook me up by telling me what part#'s from rockauto or gmpartdirect? The leak is at the front, just behind the rad on the drivers side. I would like to change them all. I cant seem to find them, and the parts I did find i'm unsure of. thanks! 1993 ssei w/ aux trans cooler.
 Post subject: Re: Transmission lines
PostPosted: Sat Oct 18, 2008 11:49 am
The 94 was leaking at a connection to the cooler in front of the rad on the passenger side.
You might have to unbolt the rad and push it back towards the engine slightly to access the clamps.
Find the leak first. Clean and degrease.
If the oil leak is on the drivers side, it could be the engine oil cooler line connections.
Last edited by 2000Silverbullet on Sat Oct 18, 2008 11:51 am, edited 1 time in total.
PostPosted: Sat Oct 18, 2008 12:21 pm
There was a recall on 92/93 Bonnevilles for those lines (too late on the recall for you now), and they are slightly different than 94 and newer. If one bursts, it can spew trans fluid on your front exhaust manifold and cause a fire. This happened on the Zilla about 5 or 6 years ago, and I barely saved the car.
Both lines cost me about $65 at the dealer.
You can find what you need on Rock Auto, but it'll take you some time to figure out which you have by the description. Look under Automatic Transmission/Oil Cooler Hose. Note that some say W/O aux cooler even though all SSEi's of your gen had them from the factory. Those would be the lines for your other car, not the SSEi.
Your third option would be to take both lines into NAPA and order them. You need to replace BOTH even if only one is leaking.
PostPosted: Sat Oct 18, 2008 1:01 pm
I can't see the lines on rock auto, so i called the dealer, and he has both for 40$. Thanks for the advice.
PostPosted: Sat Oct 18, 2008 1:27 pm
I found the lines on Rock Auto with no trouble. Which is how I gave you the path to them above.
PostPosted: Sat Oct 18, 2008 3:05 pm
All I found was the upper. That with shipping was already 40$. Maybe I'm blind.
There are no new unread posts for this topic. transmission lines
xvr843
Fri Mar 03, 2017 10:45 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Transmission cooler lines
irkwerks2
Sat Oct 18, 2008 12:24 pm
willwren View the latest post
There are no new unread posts for this topic. 99' Bonneville transmission lines
wpbrink
Fri Sep 29, 2017 11:30 pm
wpbrink View the latest post
There are no new unread posts for this topic. Oil lines
timothy_nd28
Tue Mar 31, 2009 11:02 pm
wjcollier07 View the latest post
There are no new unread posts for this topic. ELC air lines
91NinetyEight
Mon Feb 20, 2012 9:06 pm
91NinetyEight View the latest post
