It is currently Sat Sep 22, 2018 11:06 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Help with codes
PostPosted: Sun Oct 19, 2008 9:16 pm
(ICM, not ECM)
Good luck, John.
PostPosted: Mon Oct 20, 2008 12:10 pm
Year and Trim: no longer a Bonneville owner
New (old but new to me) PCM installed. Must be like your '95 Bill, 5 minute job to swap it out.
It immediately threw a 536 code and the cruise control won't work. I erased the code 3 times but it keeps coming back.
I tested the coils and all of them show the same resistance. No sign of any corrosion around the grounds but I cleaned everything anyway and put it back together. Now I have to wait till Margaret gets home to give it the torture test. Try as I will, I can not get the thing to act up for me.
Meanwhile I got a phone call telling me that she can't get the door to close on my truck. :sad5: That woman is hard on equipment. :angry7:
wjcollier07 wrote:
Darn it John...now you got me thinking mine's not big enough.
2001 F150 a basic six cyl with 5 speed manual trans.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
PostPosted: Mon Oct 20, 2008 1:08 pm
What was the name you had for this car at WCBF? :bstooges:
PostPosted: Mon Oct 20, 2008 1:17 pm
Christine. But that's because it tried to kill me. Now it's just trying to drive me crazy.
PostPosted: Mon Oct 20, 2008 2:05 pm
The car Loves you... To the car your wife is the " other " woman....LOL
Wonder if the Code 1361 will be cleared up... Let us know..
PostPosted: Tue Oct 21, 2008 11:10 am
So far, so good. Wife says car did not act up on the way home last night or on the way to work this morning. Fingers are crossed.
If all stays good for the next week or so, I'll put the old PCM back in and see if the problems return and see if my cruise controll will start working again.
PostPosted: Tue Oct 21, 2008 1:35 pm
You might have 2 bad PCM's with different problems. Might want to hit up someone with a spare they are willing to part with.
Good luck.
PostPosted: Wed Oct 29, 2008 12:38 pm
I believe it is confirmed without much doubt.
A. - Original PCM was causing the missfire and codes. 1 week with replacement PCM and no problems, swapped original back in and problems surfaced within minutes.
B. - Replacement PCM is the cause of the Cruise Control not working. When I swapped the original back in, while the missfire resurfaced, I had Cruise Control.
So, I am seriously in need of a good PCM before I can proceed much further.
PostPosted: Wed Oct 29, 2008 12:47 pm
Year and Trim: 99 SSEi
Did you swap the chip from the original PCM into the replacement?
2006 Chevy Monte Carlo SS
PostPosted: Wed Oct 29, 2008 1:29 pm
On page one he stated he did not have the eprom for the spare and was told he could put the original into it. Basically he has 2 PCM's and one chip.
PostPosted: Wed Oct 29, 2008 1:42 pm
Oh yeah - I remember that now.
PostPosted: Wed Oct 29, 2008 3:34 pm
Correct.
There are no new unread posts for this topic. codes
thunderhand
Mon Nov 17, 2008 11:19 am
sandrock View the latest post
This topic is locked, you cannot edit posts or make further replies. Air Bag Codes
nunesjeff
Mon Nov 16, 2009 9:12 pm
J Wikoff View the latest post
There are no new unread posts for this topic. A few codes...ugh.
ddalder
Sat Sep 30, 2017 4:24 pm
ddalder View the latest post
There are no new unread posts for this topic. A couple of codes: Can you help, please??
labonnevillastrangiato
Mon Jul 21, 2008 8:49 pm
93RedSled-SSE View the latest post
There are no new unread posts for this topic. Unreadable codes
Leejr57
Tue Aug 11, 2009 3:05 pm
Leejr57 View the latest post
Users browsing this forum: redmetrix and 8 guests
