It is currently Wed Sep 28, 2022 6:27 pm
 Post subject: cant fix CODE P0507
PostPosted: Mon May 23, 2022 6:37 pm
Year and Trim: SSE 1998
Hi Folks
I cant fix the code P0507. (Idle Control System RPM Higher Than Expected)
Checked in two repair shops, they checked IAC valve, Throttle Body, fixed a couple of Vaccum Leaks. But the check Engine with this code appears again.
When Idle (Normal temp) in Drive the RPMs are about 650-700 RPMs, changinf to Neutral or Park changes the RPM to aprox 1000 RPM.
I have several months trying to fix this. What else can be?
Thanks in advance
 Post subject: Re: cant fix CODE P0507
PostPosted: Mon May 23, 2022 8:32 pm
You say the shop checked the IAC, was it ever replaced?
Was the throttle stop screw moved at all?
PostPosted: Tue May 24, 2022 2:33 pm
A=IAC Valve was not replaced.
A= I dont know, they cleaned the throttle body but they didnt told me anything regarding the stop screw
PostPosted: Tue May 24, 2022 10:55 pm
I would replace the PCV valve and if that doesn't work try a new IAC.
PostPosted: Sat May 28, 2022 3:20 pm
Tnx. Will try
PostPosted: Sun Jun 05, 2022 11:24 pm
Hi folks
I changed the pcv and run the car for 1 week. Today the check engine light turned off.
Hope pcv fixed the problema
PostPosted: Wed Jun 29, 2022 1:29 pm
Hi.
Unfortunately the code was shown again.
RPM on P or N are about 1100rpms.
Could be the IAC?
thanks
There are no new unread posts for this topic. Fixed - Code 22 TPS Voltage to Low - Hard Code + Stalling
Dutch2005
Wed Jul 02, 2008 6:34 am
Wes View the latest post
There are no new unread posts for this topic. Code P1200, code P0135, and P0304
Pair of SSEI
Sun Jul 29, 2018 3:54 pm
Pair of SSEI View the latest post
There are no new unread posts for this topic. Code 18
gme148
Thu Jul 29, 2010 10:16 pm
TUFFBONNEVILLE View the latest post
There are no new unread posts for this topic. Code 57
Jasonville
67
3463
Tue Oct 09, 2018 1:41 pm
Jasonville View the latest post
This topic is locked, you cannot edit posts or make further replies. What does this code mean??
specialwoman30
Sun Jun 01, 2008 4:30 pm
willwren View the latest post
