It is currently Sun Jun 13, 2021 7:21 am
 Post subject: High Beams Won't Stay On
PostPosted: Sun Apr 26, 2020 7:58 pm
My 97 Bonneville SE has Daytime Running Lamps.
The High Beams will not stay on when I pull the turn signal lever towards me and I hear it click.
They will only stay on if I hold the turn signal lever towards me, and don't let it go. As soon as I release it, the low beams are back on.
My Haynes book shows a LAMP CONTROL MODULE controlling a HEADLAMP DIMMER SWITCH with one output for low beams and the other for high beams.
Is it a faulty HEADLAMP DIMMER SWITCH? If so, where is it located?
PostPosted: Mon Apr 27, 2020 12:01 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
The switch is on the column, under the dash. The first thing to try is to tilt the column all the way down and see if it works - that usually indicates an issue with the rod that actuates the switch is bent or the plastic plunger inside the coulumn is breaking/broken.
The switch only has three wires on it, will be a little tight to get to so you might have to let the column drop down a bit. Before you remove the switch, tape the rod in place. It can fall out of the column plunger and is difficult to get seated again.
L67 Cavalier
PostPosted: Mon Apr 27, 2020 1:45 pm
if you push the lever forward, does it work?
PostPosted: Tue Apr 28, 2020 10:22 am
Year and Trim: 2003 SSEi
THIS:
Pulling the stalk toward you only flashes the brights. To activate them push the stalk toward the dash. That's how it works on the 2000+ anyway.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Fri May 22, 2020 1:35 pm
My 97 Manual says I should pull it towards me, until it clicks, to turn on the high beams. It also says they will turn on if I pull it towards me and hold it before it clicks.
Pushing it doesn't do anything, and isn't supposed to for my 97 model, and probably not for 96, 98 and 99 model years either.
So, thanks MattStrike for answering my question about where to find the switch, and suggestion about how to remove it.
Oh, and yes, it still doesn't work if I tilt my steering wheel all the way down, so the rod must be bent or the plastic plunger must be broken.
So, I'll remove it when the weather gets warmer and report on it.
There are no new unread posts for this topic. headlight switch ??? no headlights or high beams.
88bonnsse
Wed Oct 05, 2011 4:23 pm
stompin69 View the latest post
There are no new unread posts for this topic. Help. my high beams dont work 1995 pontiac bonneville
Watchmasters
Sat Jul 13, 2013 12:29 am
motopsyco View the latest post
There are no new unread posts for this topic. High gear, high load KR
J Wikoff
53
3627
Fri Nov 08, 2013 4:48 am
J Wikoff View the latest post
There are no new unread posts for this topic. 97 SE won't stay running
Telepath
Thu Nov 29, 2012 2:59 pm
There are no new unread posts for this topic. won't stay running
mrbonne
11
2899
Mon May 04, 2009 8:25 am
93RedSled-SSE View the latest post
