It is currently Wed Dec 02, 2020 3:04 pm
PostPosted: Sat Apr 04, 2020 12:03 pm
Year and Trim: 1993 Bonneville SLE
1999 Bonneville SLE
Hi All,
I have a 1999 Bonneville SLE. Recently the contacts inside the turn signal lever began malfunctioning resulting in problems with the wiper cycle. Turn signal and cruise functions work fine.
I purchased a new oem stalk (ac delco) and following the service manual I removed the old stalk by simply pulling it straight out. It popped out with some force, but nothing appears broken.
The problem Im having is the new stalk will not fully seat into the socket. It clicks in to what seems to be a first stop, but will not fully seat so that the wiper functions will work. I tried seating the original stalk and that one will not fully seat either.
Am I missing something here?
PostPosted: Sat Apr 04, 2020 7:07 pm
A picture of the old and new might help. I'm picturing the stalk for my 92, and there's no way just pulling it out wouldn't destroy something.
PostPosted: Mon Apr 20, 2020 12:06 pm
Year and Trim: 1997 SSEI 40th
Its been a while but I beleive there is a roll pin that holds it in place.
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, 3.5 mod. Pulley, SD Headers, Intense Stage 1 tune, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
There are no new unread posts for this topic. bad multi-function switch in steering column?
veer_wide
Tue Feb 17, 2015 11:25 pm
gmman View the latest post
There are no new unread posts for this topic. Multi-function switch (TCC/ABS switch) on brake pedal?
evelandba
Thu Nov 04, 2010 5:47 am
evelandba View the latest post
There are no new unread posts for this topic. 94 Turn Signal Stalk Yoke Replacement.
2000Silverbullet
28
2766
Wed May 20, 2009 12:17 am
There are no new unread posts for this topic. Turn stalk...
ChilinMichael
Thu Jun 26, 2008 8:44 pm
There are no new unread posts for this topic. multi cylinder misfire low compression?
bdog916
Tue Aug 14, 2012 4:08 pm
J Wikoff View the latest post
Users browsing this forum: Google [Bot] and 9 guests
cron
