It is currently Wed Apr 08, 2020 12:44 am
PostPosted: Wed Feb 19, 2020 7:31 pm
Year and Trim: SSE 1998
The AC controls cant select Mode/Heat & source on my bonneville.
I believe (from other posts ) i have a problema with my vaccum hose, but I dont know hoy to find it to check if it is unplugged on the motor.
Or how can I check if it is unppluged in the control module behind the glove box. I opened the glove box, but I cant see it. Do I require to open something else?
Also.
My air suspension is not working, the compressor works If I turn on the inflator and I get some pressure (Not to much), but I suppose turning on the compressor does not inflate the suspension. Also I think my ride height sensor is not working because the compressor never turns up with weight in the rear.
What can be this other problem.
Thanks in advance.
PostPosted: Thu Feb 20, 2020 11:39 am
Year and Trim: 2003 SSEi
Search for "collapsed nipple" and you should find several leads on fixing your vacuum problem. Hopefully you will find a thread with pictures that are not hosted on stupid photobucket as those pictures will be blurry and of little help. It been a long time since I've been under the dash on a 92-99, but I think you need to remove a kick panel and look under the glove box to find the vacuum manifold.
Also, you might get better response if you separate your two problems into separate threads. It also makes it easier for others who may have problems in the future to learn from your experience once you isolate your problem.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Fri Feb 21, 2020 12:37 pm
look here for a/c..viewtopic.php?f=19&t=2884&p=27612&
get under the car rear and check the ride height sensor. you can also inspect the hard plastic air hoses for the shocks. put dish soap and watch for bubbles(leak).
PostPosted: Tue Mar 10, 2020 7:00 pm
Thanks!!!
There are no new unread posts for this topic. 1998 Pontiac Bonneville Car is not working right
Ashley.Garrison2012
19
2249
Thu Jul 19, 2012 2:04 pm
There are no new unread posts for this topic. Cluster on 1998 SSEi suddenly quit working
1998BonnieSSei
Mon Jul 20, 2009 3:20 pm
SSEi95 View the latest post
There are no new unread posts for this topic. Suspension?
irish91983
11
1763
Mon Jan 19, 2009 10:55 pm
There are no new unread posts for this topic. new suspension
Bd1703
Sun Apr 12, 2015 7:26 pm
MKMike View the latest post
There are no new unread posts for this topic. suspension
99bonnie
Thu Aug 26, 2010 5:36 pm
