It is currently Wed Jan 22, 2020 3:45 am
PostPosted: Wed Oct 23, 2019 6:16 pm
Year and Trim: 1995 Bonneville SSEi
Just bought a 1995 Pontiac Bonneville SSEi with an oil leak. After spraying brake clean near the oil leak area, I ran the engine and saw what looked like a leak from the oil filter housing seam (The piece that connects the oil filter to the timing cover). How hard is it to replace this seal?
PostPosted: Thu Oct 24, 2019 5:26 pm
It's not too bad. Be aware there is a spring and plunger being held in by the adapter. Pay attention to which way it's installed. You might get a new spring and plunger to put in, as prevention.
PostPosted: Fri Oct 25, 2019 11:02 pm
Ok, what does the spring do / what does it look like, and what is needed to be done to remove the housing?
PostPosted: Sat Oct 26, 2019 10:06 am
The spring is what regulates the oil pressure bypass. The spring is roughly the size of a double a battery. The plunger is a metal cylinder maybe a half inch long. I think the spring goes into the front cover and the plunger is on the oil filter adapter end of it.
Being supercharged, you'll have an oil cooler that has lines that run into the housing and they'll be the hardest part. Space is tight to get a wrench on them. Once the adapter is off, scraping the old gasket off will be tedious.
PostPosted: Sun Oct 27, 2019 1:31 pm
Here are some pics of the Series 2, which looks the same at the gasket.
http://intense-racing.com/PROD/OPK-671.html
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
There are no new unread posts for this topic. transmission filter gasket
Boreas
Sun Jun 12, 2011 9:36 am
Djkthegame View the latest post
There are no new unread posts for this topic. Oil Leak Above Oil Filter
azu
Sun Nov 15, 2009 5:31 pm
azu View the latest post
There are no new unread posts for this topic. Oil leak at filter seal
spoiledred94
21
3641
Mon Oct 11, 2010 1:54 am
There are no new unread posts for this topic. UIM gasket leak?
Saturn Simon
Thu Sep 10, 2015 2:25 pm
Saturn Simon View the latest post
There are no new unread posts for this topic. Oil Pan Gasket Leak
malves85
Wed Dec 19, 2012 9:43 pm
reb View the latest post
