It is currently Wed Jan 22, 2020 5:17 am
 Post subject: hvac airflow problem
PostPosted: Wed Oct 16, 2019 8:52 pm
Year and Trim: 1997 SSE
So, here's a weird one. I struggled with weak airflow from my heat and ac for a long time. I looked at every possible solution and even did the evap core cleaning process that I found here. It helped a little, but the airflow was still really weak. On a hot summer day the car would cool down about the time I got to my destination. Not good. The ac was plenty cold, I just couldn't enough air flow even though the fan was cranking. I finally bit the bullet and pulled the dash to examine everything and hopefully figure it out for good. I pulled the dash out years ago to replace the heater core, and it was a bad memory. This time it really wasn't that terrible of a job.
Here's the weird part - the interior side of the evaporator had a foam type filter wired to the core. It was really really clogged up so I ripped it off of the core and my system has worked like a champ ever since. I remember having the entire system replaced about 15 years ago, so the replacement core must have come with the filter installed. Who comes up with these ideas? You can't put a filter where you can't get access to it!
Anyway, I know this is a long diatribe, but I wanted to share because I've never heard of this problem, and it drove me nuts for a couple of years at least before I broke down and pulled the dash out.
 Post subject: Re: hvac airflow problem
PostPosted: Thu Oct 17, 2019 2:26 am
Was it maybe part of the packaging that was just left on?
PostPosted: Thu Oct 17, 2019 10:25 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
My recollection is that there are two filters on the core, one outside and one inside. The outside one is just a screen to prevent things like pine needles from getting lodged in the core because the vents it draws air from are right below the windscreen and are not filtered either. The inside foam is to catch condensate that builds up in the core so it drains out the bottom instead of getting spit through the vents.
But it's been a while since I messed with one, and a replacement part might be different than factory as well, so what I remember might be slightly incorrect.
PostPosted: Thu Oct 17, 2019 6:51 pm
I had the same issue with my 96 ; It was the collapsed nipples - not to hard to repair
PostPosted: Mon Oct 28, 2019 7:24 pm
Right you are, Mattstrike. Foam filter on the inside eventually fills up with dirt and airflow is choked off. Seems like a bad idea to me.
PostPosted: Wed Oct 30, 2019 1:21 pm
'05 STS-4
'97 LeSabre
Well, I don't think it was intended to act as a filter. I'm guessing it gets really dusty in your area, or maybe dirt roads? You could probably add a real filter to the cowl ducts, under the screens, to help with that. Not sure what the long term side effect of removing the foam would be.
There are no new unread posts for this topic. How about an HVAC problem?
SSEimatt93
Tue Apr 20, 2010 11:11 am
There are no new unread posts for this topic. HVAC problem
viper8907
Mon Aug 24, 2009 1:29 pm
sandrock View the latest post
There are no new unread posts for this topic. HVAC Blower Problem
phils97bonn
14
2030
Sun Nov 23, 2008 9:00 pm
dave1 View the latest post
There are no new unread posts for this topic. HVAC Vent Selection Problem - FIXED!!
wjcollier07
Fri Apr 15, 2011 12:54 pm
wjcollier07 View the latest post
There are no new unread posts for this topic. buick pa HVAC or EVAP or heater diagnostic problem ?
impala67
Sat Feb 05, 2011 11:42 am
impala67 View the latest post
