It is currently Mon Jul 13, 2020 4:56 pm
PostPosted: Thu Jul 04, 2019 6:14 pm
Year and Trim: 1999 SE
Updated 10:00 pm
My sister has a ‘99 Bonnie with the standard 3.8. She has been having problems with it stalling as soon as the engine warms up to operating temperature. The first time she cranks it for the day, it has a rough idle til it warms up and stalls. The second time she cranks it, it’ll start right up and idle smoothly until it stalls (a few minutes after she cranks it). However, when she tries cranking it a third time, it won’t start right up...she has to wait a couple of minutes or so for it to cool down a little bit then it’ll start...but stalls again shortly after. The following is a list of things she has already done but obviously to no avail:
Changed:
-Plugs and wires
-Fuel filter
-Fuel pump
-Crank sensor
-Camshaft sensor
-EGR valve
-Checked catalytic converter temp
She just check the codes and it was showing four different codes:
Code — Description
- P1676 stored(1/4)— driver 4 line 6
- P0102 stored(2/4)— MAF circuit low frequency
- P0742 stored(3/4)— TCC system stuck on
- P0102 pending(4/4)—MAF circuit low frequency
Any ideas? Before the codes were checked, I was thinking the MAF. However when she told me the rough idle wasn’t all the time, and it stalls at warm temperature I then started thinking about a bad coil. She’s in the process of cleaning the MAF to see if that helps a little. Thanks in advance for the advice.
PostPosted: Fri Jul 05, 2019 1:26 pm
Try unplugging the MAF. See if that helps.
There are no new unread posts for this topic. Car stalls after it warms up, restarts...(solved)
Janktu
Sat Mar 03, 2012 2:37 pm
RPACODY View the latest post
There are no new unread posts for this topic. Help! My 98 bonne stalls after engine temp is above 150
duh1980
Thu Mar 10, 2016 9:17 am
There are no new unread posts for this topic. New Dilemma; same symptoms of stalling after it warms up
DRB
Sat Mar 26, 2016 7:25 am
michtom View the latest post
There are no new unread posts for this topic. To much Gas and it Stalls. HELP!
1993SSEi
Fri Jan 29, 2010 10:41 pm
There are no new unread posts for this topic. wot car stalls???
1999_pontiac_ssei
Sat Oct 02, 2010 9:59 pm
Users browsing this forum: No registered users and 14 guests
