It is currently Sun Aug 18, 2019 9:13 pm
PostPosted: Thu Jul 04, 2019 1:29 pm
Year and Trim: 1994 SLE
I have the following issues with my '94 SLE (only 88,000 miles) and am desparately trying to decide if I should repair the vehicle or sadly say good-bye (original owner):
1. Power steering heat exchanger appears to be leaking and needs to be replaced now
2. Intermittent high engine idle (as high as 2400 rpm); drives itself. Sometimes restarting the car corrects the idle speed.
3. Intermittent false high engine temperature causing both engine cooling fans to operate, check gauges light to illuminate, and chime noise to be activated. A few years ago, this problem was solved by "violently" shaking the wiring harness between the engine and the firewall. I haven't tried that again yet.
4. Battery needs replaced. Vehicle can no longer be jump started.
Vehicle has been driven very sparingly the last 14 months (once ever 6 weeks or so for 20 min each time; has not been started or driven at all in last 3 months; garaged the entire 14 months).
Vehicle registration is due soon ($55). New tires only have 1000 miles of use. Lower intake manifold gasket, water pump, etc. replaced about 3 years ago.
Please help. Thanks.
PostPosted: Thu Jul 04, 2019 11:14 pm
#4 can literally cause #2 and #3. PCMs can also be an occaisional pain point on these era cars. Same with ground busses.
I am not sure about the rest of your circumstances, but you are also in danger of the car degrading more quickly because of not being used.
Where are you located?
PostPosted: Fri Jul 05, 2019 12:19 am
As long as the subframe, brake likes and fuel lines aren't about to rot out, I would fix it.
Get a cheap power steering cooler. ($30-40) You can bypass it but it'll cut some life out of the system.
Run new wire(s) to the coolant temp sensor from the plug at the firewall
Clean the TB with MAF sensor safe cleaner or remove the MAF if the coolant temp sensor re-wire doesn't work.
Get a new battery ($100ish) or go to the the junkyard. They sell used ones dirt cheap.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Jul 07, 2019 4:46 pm
Thank you for your reply RJolly87.
I installed a new battery, and the intermittent high idle occurred again. (The intermittent high engine temperature has not re-occurred, but I've only driven the car about 20 miles.) I have the capability of monitoring the PCM inputs/outputs with a cable, laptop, and software. Can you please help me with specifically what I should monitor for both issues? And what are proper operating ranges?
Can you please also elaborate on how to check the ground busses?
That's great advice to use the vehicle more frequently. I will remember that.
Lastly, I'm located near Dayton, Ohio.
Thanks again for your help and expertise. I really appreciate it.
PostPosted: Sun Jul 07, 2019 5:34 pm
Thanks for your reply 95naSTA.
Yesterday (Sat, July 6), I had a mechanic perform a thorough visual inspection of the vehicle. He said the subframe and fuel lines are fine. The one rear brake that has not been replaced "may fail in the future due to corrosion." Other than the issues in my original post, he also noted that the steering rack and pinion is slightly seeping power steering fluid and the transmission pan gasket is slightly leaking fluid; neither of these fluid issues require immediate attention. Am I correct in assuming you would still recommend fixing the vehicle?
I installed a new battery, and can install a cheap cooler and a new wire for the temp sensor. Thanks for the great advice.
Sorry, but it's not clear to me what to do for the intermittent high idle issue. As I posted in my reply above to RJolly87, "I have the capability of monitoring the PCM inputs/outputs with a cable, laptop, and software. Can you please help me with specifically what I should monitor for both intermittent issues? And what are proper operating ranges?" Or is there something simple I can try first?
PostPosted: Sun Jul 07, 2019 10:36 pm
Year and Trim: 2000 Pontiac Bonneville SE
The high idle can be caused by a back throttle position sensor or Idle air control.
1993 Buick Regal GS Coupe
PostPosted: Tue Jul 23, 2019 3:53 pm
Year and Trim: 1994 Bonneville SE
I had a high idle problem on my '94 Bonneville. I cleaned the throttle body, idle air control and MAF sensor with MAF sensor cleaner fluid and changed out the upstream O2 sensor. Problem has been resolved.
There are no new unread posts for this topic. Repair vacuum leaks + restore fuel trims + good gas=29 MPG!
Bob Dillon
Tue Sep 17, 2013 11:48 pm
ron350 View the latest post
There are no new unread posts for this topic. UIM EGR stovepipe repair kit
enslow
17
4265
Sun Jul 18, 2010 12:24 pm
There are no new unread posts for this topic. Recommendations for UIM/LIM repair of L36
bill buttermore
Fri May 23, 2008 10:32 am
Archon View the latest post
There are no new unread posts for this topic. fuel line repair kit?
Troyport
Fri Jul 29, 2011 4:05 pm
There are no new unread posts for this topic. Okay trivia question to help repair...
mstrwolfgang
Fri Nov 12, 2010 10:29 pm
renchjeep View the latest post
cron
