It is currently Sun Aug 18, 2019 10:43 pm
 Post subject: Engine Surging
PostPosted: Thu Jun 20, 2019 9:46 am
Year and Trim: 1994 Bonneville SE
1994 Bonneville SE
Several months ago the engine would surge upwards of 3000 RPM on startup and stay there. I pressed the accelerator several times to see if maybe it was stuck, but surge continued. Turned engine off, cleaned the throttle body with carb cleaner and seemed to fix the problem.
Yesterday, drove home from work. Stopped off at a store and returned to the car. Started it up and it surged to ~3000 RPM and did not drop. Managed to drive it the 1 mile home while holding the brakes.
Got home, turned the engine off then on again and no surge.
Any ideas? Another throttle body cleaning? TPS?
 Post subject: Re: Engine Surging
PostPosted: Thu Jun 20, 2019 1:36 pm
you can first make sure the throttle plate closes properly.
really should get it scanned for codes and make sure tps is proper
is the ses light on?
PostPosted: Thu Jun 20, 2019 3:18 pm
SES light is not on.
PostPosted: Thu Jun 20, 2019 9:15 pm
Year and Trim: White 1994 Pontiac Bonneville SE, 3800 Series 1.
Replace IAC sensor or MAF. If i had to guess it's going to be the Idle air control
1994 Bonneville SE - Series one. L27
1998 Bonneville SE - Series Two. L36
2001 Bonneville SSEI - Series Two. L67
PostPosted: Sat Jun 22, 2019 5:20 am
try cleaning it first _ may get lucky
There are no new unread posts for this topic. engine stalling, surging, rough start, PLEASE HELP
lilanqel94
21
1833
Fri Jun 12, 2015 9:41 pm
lilanqel94 View the latest post
There are no new unread posts for this topic. Surging
JMH1950
Tue Mar 06, 2012 11:05 pm
There are no new unread posts for this topic. surging
jtillman99
Thu Aug 14, 2008 2:26 pm
lash View the latest post
There are no new unread posts for this topic. Car Surging?
irish91983
Tue Dec 21, 2010 3:41 pm
irish91983 View the latest post
There are no new unread posts for this topic. Uphill Surging
ohenry5
16
4622
Tue Oct 21, 2008 12:41 pm
Bugsi View the latest post
