It is currently Tue Jul 14, 2020 12:35 am
PostPosted: Tue May 07, 2019 9:12 pm
Year and Trim: 1994 SSE
1994 Bonneville SE. Last week while driving at highway speed the engine died. Cranks but doesn't fire. Fuel pump runs and there's pressure at the schrader valve. Spark looks good at the coil packs. When I tried to scan for codes my reader just showed "error-check connection". This is a '94, so it's OBD 1.5. I've used this scanner on it successfully many times before and it works fine on another Bonneville, so I know it's not the scanner at fault. Another symptom is that when I turn the key to "run" both cooling fans run, which is not normal. Yesterday, while testing spark, fuel, etc, the battery was getting weak, so I took it out to charge overnight. When I put it back in the car, the engine started and ran normal for a few minutes. I put the scanner on it to check some values with key-on engine-off and after a few minutes it reverted to the former no-start state. At this point I can't think of any other possible cause for the "no start" than a failed ECM or bad connection/ground somewhere. I'm hoping someone here can advise me where and what to check next. Prior to this incident, the car has had the check-engine light on most of the time with two problems: cruise control only works intermittently, and the EGR valve malfunctions due to not getting the proper ground signal through the ECM. Any suggestions?
PostPosted: Tue May 07, 2019 9:53 pm
I think I would start with the ground busses near the bottom of the A pillars. Open and clean them up.
PostPosted: Wed May 08, 2019 1:27 am
Thanks, I'll check those tomorrow.
PostPosted: Wed May 08, 2019 3:09 pm
Iirc, there are two + terminals on that battery setup - the eye goes to the maxifuse centre on firewall - make sure they have good connection.
PostPosted: Wed May 08, 2019 10:05 pm
Today I checked those ground busses and they both look clean and tight, wiggled the wires etc while cranking. No effect. Also, I cleaned and tightened the batt terminals as much as I can. No effect. Later, when I was hooking up a remote starter switch to test the injectors I noticed that the cooling fans didn't come on with the key on as they have been doing, and at that point I started the engine and it ran normally at idle for about 10 minutes, then died. Started right up again, ran about 5 minutes and died, started one more time then reverted to the no-start, no-scan, cooling fans running situation. While it was running I was able to scan it and there was stored trouble code: P0755-F31 Transmission Solenoid failure. This was surprising because I'd had the battery out overnight before and I thought that would erase all codes. Anyway, I hope it's not relevant. I've never had any trouble with the transmission on this car, unless that could have caused the original stall at highway speed. After that I tested the crank sensor with a voltmeter at the ICM wiring connector, it's apparently good. I swapped a known good ICM. No change. Then I began testing the injectors with a noid light and they apparently aren't getting the signal to fire. Does all this sound like anything other than a faulty ECM, or bad connection/ground?
PostPosted: Thu May 09, 2019 9:36 am
I am vaguely remembering the fans running like that as a sign of something specific. It might be a bad pcm, I can't recall.
PostPosted: Thu May 09, 2019 8:00 pm
I've checked everything else I can think of, so I bought a used ECM on ebay and should get it in a couple days. I'll have my fingers crossed when I put it in because I don't know what else to do if that doesn't work. Thanks for the suggestions.
PostPosted: Wed May 15, 2019 3:35 am
I put in the used ECM and that seems to have taken care of everything. It didn't look very promising. One of the connectors had part of the plastic broken off and several bent pins, but I straightened the pins enough to get the connector on. The transmission fault code must have been a glitch, it shifts fine and always has, and now the EGR valve and cruise control are working again too!
There are no new unread posts for this topic. 98 Bonneville, cranks but no start
andrewisme88
Sat Nov 03, 2012 2:26 pm
andrewisme88 View the latest post
There are no new unread posts for this topic. 1995 Bonneville SE Cranks but Won't Start
Roberto
12
3354
Tue Dec 09, 2014 4:05 pm
Roberto View the latest post
There are no new unread posts for this topic. 95 Bonneville SSE Cranks, no Start. Only 2 injectors pulse.
psiguy
Wed Dec 31, 2014 4:34 pm
MKMike View the latest post
There are no new unread posts for this topic. Cranks/won't start
RedBird65
15
2519
Mon Jun 15, 2015 1:12 pm
RedBird65 View the latest post
There are no new unread posts for this topic. Cranks but no start
3800SERIESII
14
2811
Sat Mar 09, 2013 10:26 pm
3800SERIESII View the latest post
Users browsing this forum: Cantgetenuff and 6 guests
