It is currently Wed Feb 26, 2020 11:03 am
PostPosted: Tue May 07, 2019 10:55 am
Year and Trim: 1995 Bonneville SE
For awhile my right front end would growl as I turned to the left going down the road. Now it makes a popping sound on a left turn going over bumps. Where should I look for something loose or broken? Would it be the trans axle or the strut? I am going to jack it up and see what happens when I jar the wheel. Will that give me an indication? Suspension and trans axle are new to me. Thanks for any help.
PostPosted: Tue May 07, 2019 12:09 pm
the grinding may be a wheel bearing - get it off the ground and see if there is any play in wheel -you hold it at 12:00 and 6:00 position. now rock back and forth - is there play?
if there is, the bearing is out of round and deteriorating.
PostPosted: Wed May 08, 2019 6:30 am
Hey, thanks for the attention. I jacked her up and found the torsion bar on both ends where worn out. The play in the short piece connecting the bar to the wheel had rubbers that were worn out. The wheel had no play. Very solid and no noise when turning the wheel. It appears the wheel bearings are OK. The other possible cause I am told are balls in the trans axle. One or more may be worn or damaged making the growling noise when I turn while driving at speed. I fear the only way to see is removal. I have had the driver side off a few years ago giving me access to trans. It looked good and no signs of excessive wear. I can do this job. I am thinking of replacing the whole axle over repair. Any recommendations on this? Thanks for your help.
PostPosted: Wed May 08, 2019 3:04 pm
get that suspension work done and see if the noise is still there - you mean the half axel shaft? it may be, but, usually the boot is damaged and grease escapes and is replaced by dirt - you can put it in gear on a hoist while you turn the wheel from stop to stop you listen for your noise.
There are no new unread posts for this topic. 1998 Pontiac Bonneville SE. Weird noises from the front.
AshleyMae98Bonneville
Sat Aug 29, 2015 5:19 pm
Archon View the latest post
There are no new unread posts for this topic. front control arm welds breaking, causing popping noises
BW13
Thu Aug 16, 2018 8:58 pm
BW13 View the latest post
There are no new unread posts for this topic. 99 bonneville heater/ac fan makes scrapinh noises
Tabadoo
Mon Dec 09, 2013 5:19 pm
95se View the latest post
There are no new unread posts for this topic. Car Makes Squeaking Noises When Turning Left
jhl91
Mon Jul 22, 2013 11:26 am
There are no new unread posts for this topic. Attachment(s) Body Cladding Noises (Squeaky Ground Effects)
jonnevilleSSEi
12
1506
Thu Jun 16, 2011 1:35 am
renchjeep View the latest post
