It is currently Sat Apr 20, 2019 8:07 pm
PostPosted: Wed Mar 20, 2019 7:20 pm
Year and Trim: 1995 Bonneville SE
Car is a 1995 SE, it has an ABS light, I pulled this code:
ABS 25 LF WSS Circuit open/short
The service manual says to check a couple things, but I'm doing some research on the assumption it's most likely a sensor. In the book it describes replacing the front sensors and says they are right and left specific. However, what I find on line I think are complete hub assemblies that fit either side. Can someone verify that the hubs - for example a Timken 513087 - does include the ABS sensor and fits either side? If not, anyone have a source for the sensors?
Thanks for any info.
Bryan Blackwell
1995 Pontiac Bonneville SE
http://autoxer.skiblack.com
PostPosted: Wed Mar 20, 2019 9:02 pm
That's a hub and sensor assembly. I'm not so sure you can get then separate at all. They fit both sides.
PostPosted: Wed Mar 20, 2019 9:46 pm
Thanks, just what I wanted to know.
Bryan Blackwell
PostPosted: Thu Mar 21, 2019 11:27 am
Year and Trim: 96 SE
I recently changed hub and bearing assy and reused original wheel speed sensor with no problems. checked AMAZON and individual wheel speed sensors are available. wheel sensor is not right or left specific. cost about 25 $.
PostPosted: Thu Mar 21, 2019 2:18 pm
i would first check the wiring and plug
PostPosted: Thu Mar 21, 2019 8:36 pm
Was that a front or rear? OP wants a front. For the rear, I think you can get just the sensor.
PostPosted: Fri Mar 22, 2019 11:19 am
I replaced hub and bearing assy on LEFT FRONT WHEEL and reused original wheel speed sensor. upon closer look at AMAZON parts they do specify LEFT FRONT WHEEL so it seems left and right wheel sensors are not interchangeable, however the sensors can be purchased as a separate part respect to the hub and bearing assy. FYI, the replacement hub and bearing assy was from TIMKEN and did not come with wheel speed sensor.
PostPosted: Fri Mar 22, 2019 3:15 pm
The Timken part he asked about is a hub/sensor unit and it works on both sides. Got a link to the standalone sensor? I apparently haven't seen it nor can I find it with a quick search.
PostPosted: Fri Mar 22, 2019 3:28 pm
I'm coming up empty looking on Rock Auto and Amazon.
PostPosted: Fri Mar 22, 2019 8:55 pm
https://youtu.be/e0DlxEpMUco
my bad. my previous statement regarding TIMKEN HUB AND BEARING ASSY is incorrect. i just took a look and in my case, the WHEEL SPEED SENSOR is part of the HUB AND BEARING ASSY. I am not sure what car model is shown in the YOU TUBE video.
There are no new unread posts for this topic. 1995 TPS Sensor work in a 1993?
1993SSEi
Wed Dec 02, 2009 9:35 am
1993SSEi View the latest post
There are no new unread posts for this topic. 1995 SSEI Headlight Sensor turns my dashlights off.....
rklipp
Mon Apr 20, 2015 9:48 am
There are no new unread posts for this topic. 1995 Heater core replacement
ibracin
Sun Feb 14, 2010 3:41 pm
ibracin View the latest post
There are no new unread posts for this topic. 1995 serpentine belt replacement
petervn1
28
5376
Sun Dec 23, 2012 3:23 pm
Bugsi View the latest post
There are no new unread posts for this topic. 1995 Bonne Front Hub Bearings
614justin
Fri Feb 03, 2017 12:11 am
614justin View the latest post
