It is currently Sat Jul 20, 2019 4:17 pm
PostPosted: Fri Jan 25, 2019 1:03 pm
Year and Trim: 2000 Pontiac Bonneville SE
Over the past few days the blower motor on my 97 Olds 88 will intermittently not work and will not make any sounds. If I tap on the dashboard it will come right on and all speeds will properly work. Would this most likely be a bad blower motor?
1993 Buick Regal GS Coupe
PostPosted: Sat Feb 02, 2019 8:05 pm
Year and Trim: 1993 SSE
Member since Nov 2003
It could be the motor, especially if it's noisy when it runs. That's where I'd start, replaced a lot of them. I'm not familiar with your olds, but it could also be the connections behind the fan knob, fuse block, motor, or resistor pack which on my car would be inside the airbox under the hood, screwed in from the top. That resistor pack probably doesn't need replaced since all your fan speeds work, but i've seen the plug on top of it burn up.
care-and-feeding/topic2432.html
1993 SSE Since 11-12-2000
2011 Camaro 2SS
2006 Silverado 3500 4x4
PostPosted: Wed Feb 06, 2019 10:33 pm
This is my experience:
77 Chevy K20 - bad blower motor
80 Steiger (same as a corvette) - burned resistor pack (x3-4)
86 Pontiac 6000 - burned plug on the resistor pack
90 Chevy C70 - bad blower motor
93 Bonneville - bad blower controller module x2
96 Chevy 6500 - bad blower motor
98 Chevy 2500 - bad blower motor
12 Chevy Colorado - bad blower motor
They're all working now aside from the '77 that i sold for scrap...with a pretty new blower motor
2011 Camaro 2SS
There are no new unread posts for this topic. electronic climate control
christinewormley
Tue Nov 22, 2016 4:45 pm
96 SSEi View the latest post
ad356
Mon Nov 10, 2014 10:26 am
Sirius View the latest post
There are no new unread posts for this topic. converting to ecc (electronic climate control)
95se
Wed May 15, 2013 8:10 am
There are no new unread posts for this topic. Electronic Climate Control Problems
JeffCimmino
Mon Aug 10, 2015 8:59 pm
haro1225 View the latest post
There are no new unread posts for this topic. 1993 Electronic Climate Control
hebsmadwi
Wed Feb 04, 2015 6:10 pm
J Wikoff View the latest post
cron
