It is currently Fri Mar 22, 2019 5:51 am
PostPosted: Sun Jan 13, 2019 1:51 am
Son has a 1998 Bonneville which has sat for about 4 years,decided would like to use it again and we can't get it started.Added some fresh fuel to the tank but no go.Put car on blocks crawled under and unhooked inline filter to check for flow but nothing,(wife turned on key) checked for power going back to plug,nothing.(Will check again tomorrow not sure if I had a good test light ground)Just wondering if I apply power using my booster pack using grey and a black wire in plug going to pump can I test to see if pump will run?
PostPosted: Sun Jan 13, 2019 2:11 am
Security light flashing on the dash? Does it crank?
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Jan 13, 2019 7:47 am
It cranks,not sure about security light, will try again today and see.Had friend feed it some ether would try to start.Plug has 4 wires going into it,outside 2 I tested as grounds and been told grey feeds pump,what is the other one for?
PostPosted: Wed Jan 16, 2019 7:05 am
Pump shot what would you guys recommend.Should I just get the complete assembly or just change the pump on my old assembly?Pump and strainer about 115.00 Can; online in the USA but 200. up here at NAPA.Leaning toward complete.Can get NAPA brand which is a Carter for 420. Canadian or get a Spectra from the USA for around 140. Can;
PostPosted: Wed Jan 16, 2019 9:11 am
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
I would replace the complete assembly.
On this model year I believe you have to drop the gas tank.
Starting in 2000 they have an access panel in the trunk which makes the job a whole lot easier.
I would not want to have to drop the tank twice if something else is wrong with the pump.
Go with the complete assembly.
There are no new unread posts for this topic. 1998 Fuel Pump
chuck202003
17
5078
Sun Oct 16, 2011 2:17 pm
chuck202003 View the latest post
There are no new unread posts for this topic. 1998 Bonneville SE Fuel issues
chuck202003
11
2363
Thu Sep 15, 2011 11:09 am
There are no new unread posts for this topic. 95 Bonneville fuel pump location
jjlw
Thu Dec 02, 2010 11:35 pm
J Wikoff View the latest post
There are no new unread posts for this topic. 98 Bonneville SE fuel pump replacement
Rolandgp16
Mon Sep 24, 2012 2:41 pm
Rolandgp16 View the latest post
There are no new unread posts for this topic. 1999 Pontiac Bonneville SE 3.8 Fuel Pump issues.
Hurts Customs
Wed Apr 30, 2014 12:56 pm
Hurts Customs View the latest post
