It is currently Thu Jun 30, 2022 12:52 pm
 Post subject: Wiring Harness
PostPosted: Tue Dec 04, 2018 12:27 pm
Year and Trim: 1994 Bonneville SE
1994 Bonneville
Had a small coolant leak around the water pump hose connections. Moved the wiring harness out of the way to gain access to the hose clamps for tightening. Forgot to move them back into place. Alternator cooling fan shredded the wires running down to the AC compressor and sensors on the engine left side :banghead:
Wires leading to ignition coil are intact. Can the wiring harness be replaced only for the AC and engine sensors? Any idea what part # this would be?
 Post subject: Re: Wiring Harness
PostPosted: Tue Jul 14, 2020 2:55 pm
Year and Trim: 1999 Bonneville SSEi
I would just splice them back together using quality butt splices, heat shrink, electrical tape and maybe some added harness conduit.
PostPosted: Tue Jul 14, 2020 10:03 pm
So if it's the ignition module sub harness that's messed up, then yes, that can be replaced without replacing the whole engine harness.
Problem is you'll be hard pressed to find one for a 92-94. A 95+ L36/L67 might be close enough to be plug and play since every connector is the same. Hit up http://www.bonnevillesunlimited.com/ for one if you want to give it a shot.
There are no new unread posts for this topic. TCC Valve is worn, can I disconnect the trans wiring harness
Tuffguy610
17
16897
Mon Jun 14, 2010 6:31 am
enslow View the latest post
There are no new unread posts for this topic. Anyone with 96 PCM harness pinout?
SSEiMan01
Thu May 08, 2014 7:30 pm
There are no new unread posts for this topic. Wire Harness Nightmare
bonnevilleCyborg
Sat Apr 07, 2012 6:27 pm
sandrock View the latest post
There are no new unread posts for this topic. Wire up L67 using an L26 engine harness?
Sirayden
Tue Apr 21, 2015 6:29 pm
95naSTA View the latest post
There are no new unread posts for this topic. no A/C, need wiring diagram
WGesnerJr
Wed Jun 11, 2014 9:24 pm
MKMike View the latest post
