It is currently Sat May 25, 2019 11:41 am
PostPosted: Wed Oct 24, 2018 11:33 am
Year and Trim: 1994 SSEi Supercharged
Hi,
So My car is overheating, the cooling fans are not coming on. I replaced the cooling fan relays and all fuses are fine. The fans do not come on when the AC is turned on. I unplugged the coolant temp sensor and the fans do come on, but I get no reading on the dash temp gauge now. I have a few questions if anyone can please help?
1. is there a second temp sensor that controls the fans to turn on at a certain temp or is it all through one temp sensor (the one I unplugged)
2. Is it safe to drive in this condition for a few days with the fans constantly on?
3. If it's not the temp sensor, I'm thinking it might be the ECC that needs replacing? If so can I wire in an override switch from the relay temporarily to turn fans on manually and then I can plug temp sensor back in until I figure out getting a new ECC module?
Thanks all for your help
PostPosted: Wed Oct 24, 2018 8:05 pm
I know 92/93 had two sensors, one for the guage and one for the computer. Not sure if that changed for 94 with the change in pcm style. You could wire in a switch to ground the fan relay when you want the fans on in the meantime while you figure it out. I'd try to avoid running the fans all the time. It'd be hard on the battery.
PostPosted: Thu Oct 25, 2018 9:36 am
I changed the sensors (there are 2, one under the thermostat housing and one around the back ), still the fans are not coming on so think I need a new pcm? Are these interchangeable if I pick one up at a junk yard? In the meantime as I know the relay and fuse is good as fans come on when temp sensor is unplugged - I will attempt to wire a switch to ground at the fan relay and run into cabin - is this relatively simple job?
PostPosted: Thu Oct 25, 2018 11:11 am
It is pretty easy. I think it might be in techinfo.
There are no new unread posts for this topic. I have a miss in my 1994 Bonny, and it's driving me nuts.
jdesantis
Sat Mar 20, 2010 12:48 pm
willwren View the latest post
There are no new unread posts for this topic. ECC temp sensor?
Bob Dillon
Thu Jun 14, 2012 7:23 pm
RogueSSEi View the latest post
There are no new unread posts for this topic. Temp sender/sensor location on 1993 3800 ?
Arrowhead
Wed Jun 05, 2013 11:49 pm
motopsyco View the latest post
There are no new unread posts for this topic. 98 SE Stalls while driving, Cylinder misfire, o2 sensor CEL
ccfairey
Sat Aug 24, 2013 8:41 pm
There are no new unread posts for this topic. How do I remove the Coolant Sensor from the Radiator?
92'RegalGS
Thu Mar 25, 2010 12:21 pm
