It is currently Sun Feb 17, 2019 6:22 pm
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Code 57
PostPosted: Wed Oct 03, 2018 12:20 am
One of the biggest tells is the ribs around the body of the sc. If they extend to the base it's a 92/93. If they are shorter and blend into the body before reaching the base, it's a 94/95. The reason is the newer sc got epoxy coated rotors to make it more efficient, so it could be run slower and didn't need as much cooling from the ribs.
PostPosted: Wed Oct 03, 2018 10:47 pm
Year and Trim: 1993 ssei
It is the 92/93 blower. Thank you
PostPosted: Wed Oct 03, 2018 10:50 pm
I didnt think this thing would be this sensitive?? Lets say i want more power when i finally get it running right. Im gonna need to tune it.. you recomend chips or is there a plug and play device for thiese old girls?
PostPosted: Wed Oct 03, 2018 10:53 pm
Smaller pulleys, bigger injectors, nos, etc, all gonna need ecm mods to work properly.
How do you guys do it?
PostPosted: Thu Oct 04, 2018 9:15 am
I've got a chip, along with a combo of things, seen in my signature. A tune would help a lot, I think. The chip does ok, but I've changed so much that it can't be ideal. Rockers, pulley, sc, tb, maf, injectors, etc.
PostPosted: Sat Oct 06, 2018 1:46 pm
My bonni is fixed!!!! Recap,,, wrong ecm,wrong prom,wrong mass air sensor, bad grounds under drivers kick pannel, bad knock sensor. Wow that was fun...... lol
PostPosted: Sat Oct 06, 2018 2:25 pm
What was the last thing you did?
PostPosted: Tue Oct 09, 2018 1:41 pm
Mass air flow sensor... They had one from a non s/c 3.8 in there and it was telling the computer that the engine was under too much load and dumping boost. I had to fix all other problems to get the ecm to a point where it would give me correct info then i was hot on the trail. Still has a bit of a miss but i think its a week injector on #5.. next year.. Shes working great
There are no new unread posts for this topic. Fixed - Code 22 TPS Voltage to Low - Hard Code + Stalling
Dutch2005
Wed Jul 02, 2008 6:34 am
Wes View the latest post
There are no new unread posts for this topic. Code P1200, code P0135, and P0304
Pair of SSEI
Sun Jul 29, 2018 3:54 pm
Pair of SSEI View the latest post
There are no new unread posts for this topic. Code 18
gme148
Thu Jul 29, 2010 10:16 pm
TUFFBONNEVILLE View the latest post
This topic is locked, you cannot edit posts or make further replies. What does this code mean??
specialwoman30
Sun Jun 01, 2008 4:30 pm
willwren View the latest post
There are no new unread posts for this topic. EGR code 406
spoiledred94
Sun Dec 04, 2011 11:41 am
