It is currently Wed Apr 24, 2019 7:56 pm
PostPosted: Tue Aug 14, 2018 8:31 pm
Year and Trim: 1997 SSE
So I decided after 200k miles on my 97 sse, I would start rebuilding the suspension. For about a year now I've been replacing parts, (and in some cases replacing them again) and I'm getting pretty fed up.
First of all, I won't buy any Mevotec brand parts from Rock Auto again. Pretty much junk imho.
Anyway, I started getting a popping noise from under the car, especially when I turn and accelerate at the same time. When it's wet outside it's really bad - sounds like something is broken. It took me a long time to figure out what it is, but I finally found it a few days ago. The new Moog control arms I installed about six months ago have broken welds where the front bolt sleeve is welded to the arm. Fortunately they have lifetime warranties. But it still sucks that they broke. I got two replacements from Rock Auto and after I installed them, all was good. I felt like a genius, cause I've been chasing that stupid noise for so long! Now, after about 50 miles, I think the new ones have broken! I can't tell if I'm doing something wrong, or they have a quality problem. I guess I'll get a couple of arms from the junkyard, put new bushings in them, and give that a shot. Has anybody ever heard of this problem? Also, everything was torqued properly. (I'm pretty anal about that stuff)
PostPosted: Tue Aug 14, 2018 10:09 pm
I put Moog control arms on my 92 and haven't had any problems.
PostPosted: Tue Aug 14, 2018 10:24 pm
Got a photo?
I have Moog arms on my 2003 with about 20k miles on them so far with no issues.
PostPosted: Wed Aug 15, 2018 6:54 am
To confirm you should torque down when the arm is level (normal ride height). Tightening while at an angle will cause stress when the vehicle is lowered.
PostPosted: Wed Aug 15, 2018 9:01 am
I tightened the control arm pivot bolts with the car's weight sitting on the control arm as it normally would. I'll post a picture of a broken one today. This should be a no brainer, so I'm a little baffled.
PostPosted: Wed Aug 15, 2018 6:19 pm
https://photos.app.goo.gl/r4xGrvTBsMq4RuUf6
Hopefully this link works.
PostPosted: Wed Aug 15, 2018 8:25 pm
The bushing pressed into the subframe makes me want to throat punch someone.
PostPosted: Thu Aug 16, 2018 12:21 am
I agree. I never paid much attention to it, but I just don't understand the design. If the control arm is bolted solidly to the bushing, how is it supposed to move? Just the flexing of the bushing I guess. I think the designer was stoned! If it was a shoulder bolt, then maybe I could see it, but it's just bolted solidly to the bushing. The rear mount is no problem, but this front one.....I think they need a do-over.
https://photos.google.com/photo/AF1QipP ... LZ586rP2FO
PostPosted: Thu Aug 16, 2018 12:45 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Do you have a friend that's a welder? I've never looked at OEM ones, but that weld that only goes half-way around the tube part might be most of the issue. Have a welder make another pass on between that tube and the control arm right below the head of the bolt, the entire way around, in addition to fixing the existing weld break. Probably a lot less hassle than going through the RMA/Warranty process.
And, yes, the bushing deflects rotational in this setup. It might seem like a bad design, but they last a lot longer than the bushings on, say, a W-body LCA. And if the center pin of the bushing ever did separate and free-rotate it wouldn't really matter anyway because the intended job the bushing does isn't to stop rotational motion; that's just a side effect of it's manufacturing process.
Runs:
Doesn't run:
PostPosted: Thu Aug 16, 2018 8:58 pm
I think I'm just going to get a couple of junkyard control arms and put new bushings in them. I already have the fairly new ball joints on the current ones that I can use. The oem arms look a lot beefier in the area of that pivot point. Even Moog has some suspect parts these days I guess. I feel confident that the breakage is simply because it couldn't take the stress. Plus welds should never pop loose like that. Thanks for all the support and suggestions, this has been driving me crazy! I'll post an update when I think it's finally fixed.
There are no new unread posts for this topic. 1998 Pontiac Bonneville SE. Weird noises from the front.
AshleyMae98Bonneville
Sat Aug 29, 2015 5:19 pm
Archon View the latest post
There are no new unread posts for this topic. Looking for a '99 Front Control Arm
joshuagilbreath
Thu Feb 13, 2014 12:07 am
There are no new unread posts for this topic. What is causing this?
John
Mon Jul 21, 2008 10:59 pm
Bugsi View the latest post
There are no new unread posts for this topic. [94 SSE] ABS pump goes on causing engine trouble
Mcmaker
Sun Aug 28, 2016 10:23 pm
Roadrunner View the latest post
There are no new unread posts for this topic. Car Makes Squeaking Noises When Turning Left
jhl91
Mon Jul 22, 2013 11:26 am
