It is currently Mon May 20, 2019 6:49 am
PostPosted: Sat Jul 28, 2018 7:43 pm
Year and Trim: 1998 pontiac bonneville se
Has anyone replaced the master cylinder? If you have could you offer some advice on what to do or pictures?
PostPosted: Mon Jul 30, 2018 10:48 am
what is the issue with the master?
PostPosted: Mon Jul 30, 2018 10:56 am
Leaking
PostPosted: Tue Jul 31, 2018 7:45 am
The master cylinder is leaking and I will be replacing it shortly.... Brake pedal goes to the ground. Do I need to bleed the ABS system also and if so I have no idea what to do. ..
PostPosted: Tue Jul 31, 2018 10:36 am
I replaced all of my lines without doing any special ABS bleeding procedures.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Tue Jul 31, 2018 12:31 pm
Do you bleed the system with the car running or just keyed on?
PostPosted: Tue Jul 31, 2018 2:25 pm
I just gravity bled it, then did a 2 person bleed by pumping the brakes. I don't even remember having to turn the car on.
You're supposed to bench bleed the master before you install but I didn't do that either.
05 Suzuki DRZ400S
There are no new unread posts for this topic. Brake Master Cylinder on a 94 SE
spoiledred94
Fri Jul 10, 2009 3:00 pm
There are no new unread posts for this topic. Master Cylinder question
mythicSSEi
Sun Nov 02, 2008 11:45 pm
willwren View the latest post
There are no new unread posts for this topic. Master cylinder change
bobfather99
Tue Jan 20, 2009 5:13 pm
Troyport View the latest post
There are no new unread posts for this topic. Master Cylinder help needed
ChilinMichael
11
1207
Tue Jul 31, 2018 7:51 am
wpbrink View the latest post
There are no new unread posts for this topic. Rock Auto Master Cylinder: Which One?
hailwood1965
Thu Dec 22, 2016 10:16 pm
MKMike View the latest post
