It is currently Sat May 25, 2019 5:20 am
PostPosted: Sun Jul 15, 2018 4:56 pm
Year and Trim: 1998 pontiac bonneville se
Replaced rear wheel bearing as the sensor was bad... go to start car and ABS light still on. How do you reset the computer system to wipe out the abs light? New sensor tests good and lines going up to ABS control module are testing good. ..
PostPosted: Thu Jul 19, 2018 10:46 pm
Year and Trim: 96 SSEi- 157K
If the new sensor tests good, there must be another sensor that's out. The light will go away automatically once there's no code anymore.
- Rachael
PostPosted: Thu Jul 19, 2018 11:45 pm
A vehicle has to move for it to test the sensors. You might have to unhook the battery for a minute to clear an active code.
There are no new unread posts for this topic. ABS light light after replacing wheel hub assembly
Whitecrystal1
Mon Jul 25, 2011 12:23 pm
There are no new unread posts for this topic. Replacing front wheel bearing assembly
Yagyu
Mon May 16, 2016 11:04 am
J Wikoff View the latest post
There are no new unread posts for this topic. Help replacing a door light bulb.
Krenzy
Sat Mar 24, 2012 9:16 pm
Krenzy View the latest post
There are no new unread posts for this topic. map, dome, fog light switches when replacing headliner
rcmaly
Sun Oct 19, 2014 4:57 pm
rcmaly View the latest post
There are no new unread posts for this topic. Steering Wheel Controls, Light up but that's it...
1993SSEi
Fri Dec 11, 2009 12:22 pm
1993SSEi View the latest post
