It is currently Tue Mar 19, 2019 3:12 pm
PostPosted: Sat Jul 14, 2018 11:35 am
Year and Trim: 1994 Bonneville; NOT super-charged; likely SSE
For my 1999 LeSabre (but likely same for 90's Bonnevilles):
High-Mount brake light wasn't working ... so replaced the 1156 bulb ... still didn't work.
So: disconnected the bulb socket from the harness connector and looked inside the socket with magnifying glass.
Looked like the socket-tube side-contact tab (to touch-to the bulb-base side) may have been mostly broken-off
-so:
with small screw-driver pushed-outward that remaining piece of the side-contact tab
(got it to the point I could barely get the bulb back into the socket ...
... but was good because the side-tab was then gouging into bulb side).
Put it back together into the brake light assembly ... so far for past few days working OK.
So I went to find the GM part# for the socket
- found this (of course, discontinued regardless socket is used up to year 2005 GM models):
http://oemcats.com/oem-parts/05972532.html
So:
anyone else have any experience with using a universal 1156 socket for the GM # 05972532 socket ?
Maybe this
(since the diameter size is in ballpark of exact 1-inch diameter hole in the high-mount light assembly, with 2 twist-in tabs) ?:
Dorman 85804 ?:
https://www.dormanproducts.com/p-12588- ... in=keyword
Thanks.
PostPosted: Fri Jul 20, 2018 2:34 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I don't see why a universal socket wouldn't work for most people.
The lamp monitor on the SSE/SSEi might not like a universal socket, I've never tried though.
Runs:
Doesn't run:
PostPosted: Sat Aug 04, 2018 3:51 pm
Here the further story:
I also have a 94 Bonneville ... so ... today I got into the Bonne trunk and disconnected that 3rd-brake-light bulb-socket (same GM part # 05972532) from the OE wire-harness and from the light-house assembly.
After un-screwing the 1156 bulb from the Bonne 05972532 socket, I saw what is the flawed GM-design with that socket:
the metal ground-tab was ~ 50% eaten-thru ... the socket-bulb ground-tab corrodes right at the point that the metal ground-tab has a tension-bend to meet against the side of the bulb ... so ... when the metal ground-tab bend becomes totally eaten-thru (like on the 99 LeSabre) then the bulb looses it's ground connection (since the body of the socket is totally plastic).
So after seeing that, I am even more miffed at the fact that GM discontinued that socket GM part # 05972532 and that part currently isn't available anywhere new or NOS except supposedly from a Canadian dealer that sells the part for $9 CDN + international shipping to the U.S. for total $43 CDN (~ $34 US dollars).
I'm miffed because it's obvious this socket appears to be an eventual needs-to-replaced part on all the GM vehicles that used this part from early 1990s up to ~ year 2005 (since it needs to be replaced on the 2 of the 2 vehicles I have (99 LeSabre and 94 Bonne) that's a 100% replacement-rate) ...
... but as I have stated:
the part isn't available new nor NOS ... and ... from what I've seen today it doesn't make sense to buy that socket from a salvage yard since the socket metal ground tab will likely be just as corroded (or totally corroded to malfunction) from any used GM vehicle.
So: the alternative:
I did buy the Dorman part # 85804 universal 1156-bulb socket (that I had posted originally in this chat couple of weeks ago) ...
... that Dorman universal socket does appear to fit solid-enough in the hole of the 3rd-brake-light assembly,
since the 2 side hold-in tabs on that Dorman socket "squeeze together" to fit that socket into the assembly
(then let-go of the "squeeze together" on the 2 side hold-in tabs and the Dorman socket is solid-enough held on it's own into the assembly)
- only thing I have left to do is cut the OE harness 2 wires then crimp in couple of spade connectors and hold the harness ground-wire
to the body of the universal socket with a small hose-clamp (or maybe solder the ground-wire to the universal socket body).
Regardless: to me it's just "not right" that GM part # 05972532 currently isn't available new for not more than ~ $15 US dollars ... since to me it indicates that GM isn't supporting it's fans for what appears to be a normally-required replacement part.
There are no new unread posts for this topic. High mount, center brake light socket
ColdScrip
Thu Mar 05, 2009 6:06 pm
ColdScrip View the latest post
There are no new unread posts for this topic. Brake line leak...what is this part?
John Deere Boy
11
2673
Sat Feb 19, 2011 10:57 am
John Deere Boy View the latest post
There are no new unread posts for this topic. Flex brake line to master cylinder part number
3800FTW
Mon Apr 22, 2013 8:31 pm
3800FTW View the latest post
There are no new unread posts for this topic. BRAKE! light
Ben1998SLE
Fri Jul 06, 2012 2:57 pm
reb View the latest post
There are no new unread posts for this topic. The e-brake light comes on
chadeyboy85
Tue Oct 20, 2009 12:05 pm
chadeyboy85 View the latest post
Users browsing this forum: No registered users and 16 guests
