It is currently Mon Feb 18, 2019 9:04 pm
PostPosted: Fri Jul 06, 2018 3:10 pm
Year and Trim: 1995 SSEi
I have a 1995 SSEi with low mileage (70k), but there was a recent oil issue and now the engine is locked up and needs to be rebuilt or replaced. If possible, I'd like to improve the performance if I'm going to take the time/money to fix it. Here are the options that I think I should be considering:
1) Rebuild the Series I supercharged engine
2) Replace with same engine
3) Swap Series II or Series III engine
4) Swap with some FWD V8 like a Northstar or LS4
5) Don't fix the car
I welcome your advice on the most practical thing to do in my situation. I'd like to keep the car and continue using it, but don't want to sink more than ~5k in this project.
Thanks for your help.
PostPosted: Fri Jul 06, 2018 4:17 pm
Most practical for time would be to drop in a reman Series 1 (get a 94/95 to ensure it was the latest heads and rotating assembly).
Most practical for money/time would be a used Series 1.
Most practical for money would be to fix it yourself.
PostPosted: Sat Jul 07, 2018 5:33 pm
just my 2 cents, forget the NorthStar. I don't think it will fit. - BC
PostPosted: Mon Jul 09, 2018 9:58 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Most practical in terms of modding/performance is a series 2 engine and 4t65e-hd swap. Tons of aftermarket support (somewhat starting to dwindle lately).
LS4 or Northstar won't have a lot else you can do in terms of mods after the swap. I don't know that anybody has done one of these yet - I know at least one LeSabre T-type had a Northstar swap done but it was an early Northstar. probably going to need all custom motor and trans mounts on top of the usual engine swap fabrication business.
Runs:
Doesn't run:
There are no new unread posts for this topic. New cars list of problems needing solutions 92 ssei
HonchoRyanC
Tue Sep 07, 2010 3:49 am
renchjeep View the latest post
There are no new unread posts for this topic. Needing help with my 1992 SSE
Cedict
Sat Mar 15, 2014 10:01 pm
Kajidono View the latest post
There are no new unread posts for this topic. Needing a bit of help; headlight switch wiring
Sam Ellis
Wed Dec 16, 2015 8:39 am
Sam Ellis View the latest post
There are no new unread posts for this topic. Needing blend door location for 98 bonneville
Moville109
Tue Oct 25, 2011 9:18 pm
willwren View the latest post
There are no new unread posts for this topic. 93 ssei engine needs help!
Rickler
Wed May 09, 2012 7:52 pm
J Wikoff View the latest post
