It is currently Mon Feb 18, 2019 8:46 pm
 Post subject: 1997 Transmission Swap
PostPosted: Wed Jun 20, 2018 8:11 am
Year and Trim: 1998 SE Silver
1997 SSE Black
1994 Regal GS Black
Hi all!
I have a 1997 Bonneville SSE with the NA 3800 and 4T60E(M13) transmission that has started to slip when hot(95 degree day, driving 2+ hours). I was looking to swap a 4T65E or 4T65E-HD out of a 1998 of 1999 Bonneville.
Would either be a direct swap(no computer or wiring needed)?
And if I was to get a whole parts car, should I do the 4T65E, or 4T65E-HD?
Want to get the car back to being reliable and my 1998 Bonneville SE(4T65E) that I had had a different gear ratio that was more suitable for our driving.
Thank you!
PostPosted: Thu Jun 21, 2018 2:52 pm
65s use a solenoid to set line pressure and 60s use an external vacuum modulator. Your PCM can't control the line pressure of a 65.
The easiest thing is to find your trans. If you don't want to mess with tuning, the second easiest thing is wiring in a 98 setup from a L36/65-e equipped car.
Any 65-hd trans will have a gear ratio that only came with a L67. So, tuning required.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Thu Jun 21, 2018 7:05 pm
1997 SSE Black
1994 Regal GS Black
Would getting a 98 Bonneville with the 4T65E parts car with the PCM and everything work? Or would that be too involved and still need tuning and such for the 97?
PostPosted: Thu Jun 21, 2018 8:53 pm
Yeah, I'm sure that would have everything you need. Some minor wiring might be required.
05 Suzuki DRZ400S
There are no new unread posts for this topic. 1997 Transmission Oil Line
BonBon
Tue Nov 30, 2010 12:19 pm
There are no new unread posts for this topic. 1997 SSEI Transmission Compatibility
jballagh
Wed Dec 21, 2011 6:06 pm
There are no new unread posts for this topic. 95 Bonneville transmission and / or engine swap
scottauch
Sat Jun 12, 2010 8:53 am
willwren View the latest post
There are no new unread posts for this topic. 1997 SE w SC ??
dgleichner
Fri Sep 23, 2011 4:10 pm
There are no new unread posts for this topic. Oil Leak on 1997 SE
94SilverSSEi
11
2109
Tue Aug 03, 2010 10:45 am
zuper8 View the latest post
Users browsing this forum: Exabot [Bot] and 15 guests
cron
