It is currently Thu May 28, 2020 5:08 pm
PostPosted: Tue Jun 12, 2018 2:50 am
Year and Trim: 1998 pontiac bonneville se
Have no idea why on the hwy. the car is wanting to pull to the right violently and the steering wheel is shaking big time. Tires appear fine. Would the motor mounts be involved and if so how do you check them and how many are there?
PostPosted: Tue Jun 12, 2018 8:51 am
if it pulls hard to the right with vibration, I would bet its a front end issue - could be tie-rod flapping around
get it off the ground and check the ball joint, tie-rods - control arm..... you know, front end stuff.
did you do some work on the front end? - start there.
PostPosted: Wed Jun 13, 2018 4:55 pm
Could be a caliper dragging and heating up the rotor on one side. As the rotor heats, any warping grabs at the brake pads harder than when cold.
Or could be the brake fluid line has swollen and isn't letting the brake fluid back out when the pedal is released. This holds the brake caliper on. The line allows the fluid through to the caliper because of the very high pressure when pedal is applied, but the reverse flow is blocked because the caliper exerts little pressure to push the fluid back to the master cylinder.
To check, stop by using the emergency brake only carefully when the car has been doing the pulling and see if one of the front brake rotors is extremely hot, especially compared to the other.
There are no new unread posts for this topic. 1995 Bonneville: Bad idle, stalling, shaking, backfire
Twystedhemp2
44
5164
Sat Jan 04, 2020 3:00 pm
95naSTA View the latest post
There are no new unread posts for this topic. Towing, or pulling?
93Bonneville
Mon Feb 06, 2012 1:58 pm
There are no new unread posts for this topic. Hard pulling issue
lowlyfe95
Mon Feb 28, 2011 7:10 am
There are no new unread posts for this topic. Headliner pulling questions
J Wikoff
Thu May 07, 2009 10:34 pm
There are no new unread posts for this topic. Shaking above 60 mph
Andrew88
Mon Nov 03, 2008 6:03 pm
Andrew88 View the latest post
