It is currently Fri Mar 22, 2019 5:57 am
PostPosted: Sat Jun 02, 2018 8:39 am
Year and Trim: 1995 bonneville se L36
Going thru fuses underhood and found a looks goldish, its soldid and cant see thru to see if blown? Says 506 DC & 20A in yellow paint and BREAKER stamped on it.
Also whats best way to check passanger side inside fuse panel? I removed kick panel under dash but looks very right
1995 L36 is not crank no start. Turned cam manually w plugs out and in and it turns, so not locked up right? Was slow 2 start for a few days and started up and CEL was on and was sluggish and drove and came back and few groans anf eventually noth8ng. All dash lights come on and headlights dim when cranked. Security light doesn't blink and goes out.
PostPosted: Sat Jun 02, 2018 9:42 am
yes, that gold thing is a breaker so its prob. for the lights
there should be a little panel door hiding fuses on pass hush panel ..............here is your manual...........https://my.gmc.com/content/dam/gmownerc ... owners.pdf
check to se if battery is good and cables are connected snug and not rusty. see if it cranks
PostPosted: Sat Jun 02, 2018 12:24 pm
The gold fuse is good then and wouldnt cause no start?
Any easier way than reverse sitting in chair to check passenger side fuse box?
I cant run a jumper cable from pos battery to starter can?
Was trying 2 make sure its starter 100% before removing 2 bench test. Seems like something caused starter 2 lock up or go out, seems like something electrical.
PostPosted: Sat Jun 02, 2018 2:54 pm
YES BREAKER is good - not the issue
no - upside down in pass seat looking up is easiest - check for ignition fuse in boxes
yes you can run a 12v wire to test starter - test battery first
PostPosted: Sun Jun 03, 2018 1:17 am
Are you talking about the fuses between the glovebox and A pillar? You can take the glovebox liner insert out to look at those too.
PostPosted: Wed Jun 06, 2018 6:11 am
All fuses were good on passanger side only had 3 relays, all looked good and bot corroded.
Driver side BUS connector under carpet still looked good and intact.
Battery was getting 12 volts at starter didnt have helper yet to crank test it.
Idk why CEL to be instantly on and sluggish while driving, taking awhile 2 get 2 next gear & shifting hard. Then backed into curb caddy cornered pretty hard and bounced and then no start, no crank.
If SECURITY light goes out on dash after a few seconds, it couldn't be VATS could it?
Hear fuel pump prime on 1st try 2 crank and back to ON then Ctank again and then no sound. Like this everytime since no crank no start
PostPosted: Wed Jun 06, 2018 8:40 am
check the battery to make sure it holds a good charge - I would do a load test or get a good working one to test the starter. you can try a boost also.
no, if the VATS is the issue, it should flash and stay flashing - its not VATS at this point.
did you check the wires from battery to starter?
PostPosted: Wed Jun 06, 2018 9:04 am
Havent split open battery wires but they look decent at battery and not corroded or discolored.
Engine block ground was pretty oily, sprayed it w brake clean and shined it up. Going 2 get a known good battery and try it
PostPosted: Wed Jun 06, 2018 5:26 pm
ok, good, no need to split - do you have 2 wires from battery?
one goes to the maxifuse centre and the other to starter
make sure they both have good contact
yes, test with good battery - it may be that simple !
PostPosted: Thu Jun 07, 2018 2:31 am
Yes 2 wires from battery, maxifuse L ground looked good 2.
Could battery be bad even if parts store said it was good.?
PostPosted: Thu Jun 07, 2018 8:20 am
that would depend on how reliable the guy at the part store is.so I would say yes.
proper way is to fully charge and do a load test to see how fast it discharges. - try a boost and see if the starter moves. if yes, try working good battery.
PostPosted: Fri Jun 08, 2018 12:07 am
The battery wire at starter, it should not move at all?
You put alot of pressure on big wire and move it maybe 1/16 th.
I need 2 try a good battery, neighbors have bigger GMs w side post.
PostPosted: Fri Jun 08, 2018 8:27 am
you dont want to strip it so tighten until snug and then 1/4 turn should be fine - make sure the contacts are clean.
get that GM battery to test starter - charge it first
This topic is locked, you cannot edit posts or make further replies. 1995 bonneville se solid gold 20amp maxi fuse
614justin
614justin View the latest post
There are no new unread posts for this topic. Cooling fan maxi fuse blowing?***Solved***
Sacaledus
Tue Nov 04, 2014 11:57 pm
Sacaledus View the latest post
There are no new unread posts for this topic. maxi fuse relay center diagram 92 SE
calebnalyssamom
Sun Jul 18, 2010 12:42 am
mmiller View the latest post
There are no new unread posts for this topic. Bolts or whatever to remove maxi fuse relay center?
jjbrog
Thu Feb 27, 2014 5:22 pm
jjbrog View the latest post
There are no new unread posts for this topic. 99 Bonneville SE fuse problem has me looking ro help!
rjbandy
Mon Jul 09, 2012 5:36 pm
rjbandy View the latest post
