It is currently Wed Jun 19, 2019 9:44 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Sat Jun 02, 2018 8:39 am
Year and Trim: 1995 bonneville se L36
Going thru fuses underhood and found a looks goldish, its soldid and cant see thru to see if blown? Says 506 DC in yellow paint and BREAKER stamped on it.
Also whats best way to check passanger side inside fuse panel? I removed kick panel under dash but looks very right
1995 L36 is not crank no start. Turned cam manually w plugs out and in and it turns, so not locked up right? Was slow 2 start for a few days and started up and CEL was on and was sluggish and drove and came back and few groans anf eventually noth8ng. All dash lights come on and headlights dim when cranked. Security light doesn't blink and goes out.
There are no new unread posts for this topic. 1995 bonneville se solid gold 20amp maxi fuse
614justin
12
644
Fri Jun 08, 2018 8:27 am
96 SSEi View the latest post
There are no new unread posts for this topic. maxi fuse relay center diagram 92 SE
calebnalyssamom
Sun Jul 18, 2010 12:42 am
mmiller View the latest post
There are no new unread posts for this topic. Cooling fan maxi fuse blowing?***Solved***
Sacaledus
Tue Nov 04, 2014 11:57 pm
Sacaledus View the latest post
There are no new unread posts for this topic. Bolts or whatever to remove maxi fuse relay center?
jjbrog
Thu Feb 27, 2014 5:22 pm
jjbrog View the latest post
There are no new unread posts for this topic. 99 Bonneville SE fuse problem has me looking ro help!
rjbandy
Mon Jul 09, 2012 5:36 pm
rjbandy View the latest post
